G5X2 on a 250-300 shot?
Old Jan 27, 2004 | 01:30 AM
SNAXS's Avatar
Default G5X2 on a 250-300 shot?
Will it do OK? I plan on forging the block and spraying it but I dont know if the X2 Cam can do it?
THanks
Jacob
Old Jan 27, 2004 | 08:15 AM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Yeah, you'll do fine. The G5X2 along with most LG Cams love the spray. What did you order it on, a .112, or .114 LSA? A 250-300 shot is rather large however, there are better cams out there if your going for a strictly Nitrous setup.
Old Jan 29, 2004 | 08:48 AM
SNAXS's Avatar
Well its on 112 LSA. The thing is that I ordered a forged block with all the Lunati Goodies and even a forged crank. The block can probably handle around a 330 shot. But Ill spray the cam anyways. Thanks. BTW: Any thoughts of what it might run?
Forged Block
MTI S2 Heads
G5X2 Cam
250 shot of TNT
Moser 12 Bolt
Fully Built Tranny
Yank TP 4400 Stall <---Might change that
Thanks
Old Jan 29, 2004 | 09:52 AM
BMW ///M Nerd
Well you should definately be in the 10s. Which is pretty bad ***, but if you had gone on a .114LSA you might have been a little better off. You would be able to get that bad boy to idle ok (A4), and you would have add a bit less overlap to make full use of that big shot of nitrous. Sounds like a kick *** setup.
Rob
Old Jan 29, 2004 | 10:20 AM
niphilli's Avatar
Exhaust Flow is crucial to N20 setups. You want a cam with lots of exhaust duration (The X2 has lots) and heads with VERY good exhaust ports. TEA makes some great N20 heads, so does Cartek.
Old Feb 1, 2004 | 01:35 AM
SNAXS's Avatar
Thanks guys. But who makes the X2? I think my MTI S2 Heads will work fine wont they?
Old Feb 1, 2004 | 08:15 AM
niphilli's Avatar
LG Motorsports makes the X2, I am sure your heads will be fine. The only reason I mentioned TEA and Cartek is because they have both done some research for N20 with their exhaust ports. I have seen some freakish results with a small shot on their heads.
Old Feb 1, 2004 | 09:30 AM
07BlueDevilZ06's Avatar
get a large stepped header like kooks it will produce the best power for ya
george
