Home port and polish
I know its suppose to be rough on the intake and its good to be smooth on the exhaust to prevent carbon build up. For the combustion chamber, is it ok to be smooth or should some texture be left? Also what tools are you using?
BTW, WD40 or a similar product works well at keeping the cartridge rolls from loading up with material.
The first set of heads I did I was around 16-18. I thought I could get away with my father's drill and an old carbide burr. I did more damage than help.
Years ago I bought a DIY porting kit because I needed some of the components. I still have it. I'll see if the booklet is still in it and post the info here.
If you are afraid to use a carbide burr, you can get away with rolls and buffs just to take off the sharp edges and contour things a bit, just don't go crazy, and apply tape around the valve seat area to avoid damaging it with the grinder and tools. I have rolls from 60 grit up to 220 or so. The 60 grit rolls will remove more material than expected, so you could probably get away with just the rolls if you want to remove the high spots and smooth things.
Edit: Standard Abrasives Deluxe porting kit. I'll bet Summit, Jegs, etc has it. Just google for the best price. If you are going to give it a go, I have a quantity of cartridge rolls, mandrels, and a tool speed controller you can have cheap. I don't use the tools much anymore, so I should part out some of it.
Did a pretty good job staying from the valve seats. Should I hit the valve seats with some sand paper? If so, what grit?
I have a die grinder and some other tools, should be plenty to finish the job. I think Ill pick up some cartidges tomorrow! Theres so many god damn shapes on the CC, Ill end up sanding a good bit of it by hand I think
This is for an FI application btw.
I have done the trick with the valve in a drill, with rubber on the stem while in the chuck, to polish off carbon. I think I used a scotchbrite pad and some wd40 while the drill was spinning the valve.
Thanks for all your help!
