compression ???
Old Sep 19, 2010 | 06:10 PM
firehawk196's Avatar
Default compression ???
how much compression can i run on pump gas some say i can go as high as 12.1 ??
Old Sep 19, 2010 | 06:15 PM
blsnelling's Avatar
I went for 11:1 on my build. You'll want to know your dynamic compression ratio as well. Your cam will affect that.
Old Sep 19, 2010 | 09:43 PM
camz28arro's Avatar
12.0:1 SCR would be pushing it on 93 octane but there are a lot of other variables. I would build for 11.3-11.5 just to be safe and make sure you can run max timing.
Old Sep 20, 2010 | 07:36 AM
chrs1313's Avatar
11.9:1 here but I have some good heads that are very efficient, low timing 26* max...
also make sure to tighten up the quench to reduce detonation...
I run a .040 cometic...
Old Sep 20, 2010 | 09:47 AM
Jon@Texas-Speed's Avatar
It just depends on the setup and tune. You would need to know all the cam specs and how much timing will be in the motor. I would say it can be done but it might not be the best way to go. Post up some more info. if you have it.
Jon
