What are stock heads flowing?
Old Jan 28, 2004 | 04:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default What are stock heads flowing?
Anyone have stock head flow numbers for 5.7's, 5.3's, 6.0's and LS6's?
Old Jan 28, 2004 | 05:14 PM
Damian's Avatar
LSX Mechanic
John, get ahold of Jason @ TR. He's flowed all the years and has the answer to your question. You might be able to do a search and find it, I have seen him post the #'s before..
Josh
Old Jan 28, 2004 | 05:20 PM
verbs's Avatar
There have been a few posts on here with stock flow #'s.....I'd try a search.
Old Jan 28, 2004 | 05:25 PM
LS1derfull's Avatar
In a nutshell John they all flow around 235 cfm in the .500" lift range, LS6 and 6.0 slightly higher. Exhaust is around 170cfm at same lift on all. This I/E ratio is why LS1 seems to like single pattern cams or even higher intake to exhaust splits.
Old Jan 28, 2004 | 07:38 PM
jrp's Avatar
jrp
SN95 Director
posted by jason not to long ago
http://ourworld.cs.com/jrpws6/stock53.jpg
http://ourworld.cs.com/jrpws6/stock60.jpg
http://ourworld.cs.com/jrpws6/stockLS1.jpg
http://ourworld.cs.com/jrpws6/stockLS6.jpg
Old Jan 28, 2004 | 07:45 PM
Leatherneck's Avatar
Is it me or didn't somebody say that 6.0's flowed the same as LS6's?
Old Jan 28, 2004 | 09:26 PM
absolute's Avatar
6.0's and ls6 heads dont flow anything alike. Im looking for the flows I have on stock heads all I have are intake flows on 862, 241,806,and ls6 heads through an ls6 intake. I will look for the other flow sheets when I get back to work tommorow
-------241--ls6---806--862{5.3l
200 - 134 -135 - 127 - 128
300 - 185 -186 - 179 - 176
400 - 216 -220 - 212 - 204
450 - 222 -233 - 214 - 213
500 - 226 -238 - 220 - 216
550 - 228 -238 - 220 - 210
600 - 228 -236 - 221 - 210
Old Jan 28, 2004 | 11:53 PM
I was looking at the numbers that were posted on Jason's flow sheets. 6.0's seem to flow considerably less than the LS6 casting. 6.0 heads are being advertised as having the same flow and port design as the LS6's minus the larger combustion chamber on the 6.0's. If this is true and all conditions being relatively similar on the flow bench how could these numbers be so different?
Old Jan 29, 2004 | 09:34 AM
2000Firehawk's Avatar
WOW... the 97-98 head, [806], flows that bad...
The 5.3 head with a smaller valve is about the same...
Is it because of the 97-98 intake valve that doesn't have a 'back-cut'
to it ...
Dave
Old Jan 29, 2004 | 10:34 AM
BigTex's Avatar
The LS6 head on Jason's pictures says it was flowed with a "Radiused Inlet" on the intake port. None of the other heads have that inlet. Would this skew the LS6 numbers some compared to the other 3 heads?
Old Jan 29, 2004 | 11:16 AM
Jason99T/A's Avatar
I can shift faster than you.
All heads were flowed with a radiused entry on the intake port and the exhaust port was flowed open.
Old Jan 29, 2004 | 11:34 AM
HOSS99's Avatar
Hot Rod 2/04 has flows listed for Stock LS1, Stock LS6, GM PP LS6, and AFR Ported Heads. I can't remember the #'s, I'll post them tomorrow if nobody beats me to it. They are in the AFR article.
Old Jan 29, 2004 | 01:43 PM
onehardmaro's Avatar
Got this chart from here not to long ago. I cant remember who posted it.
Old Jan 29, 2004 | 02:09 PM
TTPMatt's Avatar
The numbers you want to look at are the ones attached to a stock ls6 intake. A head can flow really well, but when put through the intake fall on it's face.
Yes, the LS6 heads could see 20+ cfm more without an intake, but that does nothing to compare it to real world values. You must flow all heads through the same intake to have a comparison. Due to the nature of the ports, a lot of turbulence occurs when air enters the heads from the intake. When you look at a LS6 head that may flow 260cfm through a radiused inlet vs. a LS1 head that flows 230cfm through a radiused inlet -- this means nothing. In the real world you are not flowing air through a radiused inlet, but you are flowing it through an intake manifold.
Jay and I did the testing one day I was at his shop and I can confirm the following numbers
Through the same exact LS6 Intake Manifold
Bottom Line: Throw away the flow #'s through the radiused inlet because in the real world you'll never have that condition.
Old Jan 30, 2004 | 07:09 AM
ttt for Jay...
Old Jan 30, 2004 | 08:03 AM
Scott Turvey's Avatar
You mean exhaust to intake don't you?
Old Jan 30, 2004 | 10:30 AM
MYTURBOT/A's Avatar
The stock ls1 flows better then the 6.0s allegedly better D-shaped exhaust port. what gives?
Old Jan 30, 2004 | 11:19 AM
Nick Agostino's Avatar
To make a fair comparison they must be tested with the same inlet mediums. A radius opposed to say an intake can make a 20-30 cfm diff. on the Ls1 style heads.
Old Jan 30, 2004 | 12:31 PM
SStroked 410's Avatar
I though the 6.0l and LS6 are the same heads "BARE" with out cc's, valves ect?????
Old Jan 30, 2004 | 09:44 PM
LS1derfull's Avatar
YES, exhaust to intake or intake to exhaust, they mean the same its your choice how to say it.
