NEED HELP!! 2 different lifters in motor. Pushrod advice ASAP!!!
Ok guys here is my problem. We did a cam install last weekend and put in an MS3 cam with stock 853 heads. We installed patriot dual gold springs and TSP 7.400" pushrods.
So heres my problem. In the process we decided to go ahead and install new LS7 lifters, so we pulled the passenger side head and swapped out the lifters no problem. THEN we went to pull the drivers side head and it wouldnt come off. It had ARP headbolts and whoever owned the car before torqued them WAY beyond spec and rounded one off. So after three days of trying we abandoned hope on getting that head off.
So now im sitting here with LS7 lifters on the passenger side and LS1 lifters on the drivers side. I talked to a GM Tech and he said "Oh its no biggie the LS7's are stock replacements." but I know that the plunger height is .050" taller so with the 7.400's all around my preload will be different on each side of the motor.
Is having a different preload on each side a catastrophoc problem or what. I was told by several shops that it is a problem that can be addressed by different length pushrods on each side to even it out. I know that my best course of action is to get a PR checker and measure then go from there. But for right now can I run what I have without risk of serious damage till I do??? Or does anyone have an idea on the lengths I may need to run to stay out of trouble?
P.S. - Please dont tell me I need to run the same lifters on each side or start talking about how to get the head off, I know all of this and wish I could but as of right now this is the situation I am faced with and am looking for advice on how to make the best of it. Thanks in advance!!
LS1Tech Premium Sponsor
Like I told you yesterday on the phone, you need to measure for pushrod length and order 8 of each length...they will be different lengths. It costs the same amount of money to get 8 of one length and 8 of another as it does to get 16 of the same length. Any vendor/sponsor here that is worth his/her weight in salt should be able to get 8 of one length and 8 of the other for you!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes stock length is 7.400" but the cam has a smaller base circle I believe and the LS7's have a different plunger depth. All of which can effect the need for different pushrod length.
http://www.trendperform.com/measuring.html
There's a little reading about measuring for pushrod length and gauge length versus tip-to-tip length for anyone who's interested.
__________________
The stock pushrod's gauge length is actually 7.38x"....the aftermarket ones you have are 7.400" gauge length, which accounts for the slight difference in base circle diameter on many of the aftermarket camshafts.
The correct answer here is "No". I have driven around with too short and too long of pushrods before. Even raced the car a few times. This was my learning curve with aftermarket cams and non-adjustable rocker arms. Engine was driven and raced apprx 5K miles. Back then, the sewing machine noise was refered to as normal for larger cams and the LS1. Then came a lifter failure and I decide to check things more thoroughly. I think you could get by for a short period of time and taking it easy on the rpms. This is just my opinion from past experience with pushrods and aftermarket cams.
Extremely easy way to remove the striped head bolt is to simply use a die grinder or demel tool and remove the head of bolt. After the the rest of the bolts are removed pull the head and use a vise grips to remove the shaft.
