problem with valve springs
Old Sep 29, 2010 | 10:33 AM
02_Firehawk's Avatar
Default problem with valve springs
ok
i have ls6 heads
a comp cam with a .625 life
i bought the patriot dual gold valve spring kit, and the inner valve springs are breaking..
any ideas of why this can be happening?
it says the springs are capable of a .650 lift
Old Sep 29, 2010 | 10:40 AM
incbed's Avatar
Does the heads have factory valves or are they after market,,,also are you using 1.7 rocker arms??
Lastly how old are the springs and how many RPMs are you turning the engine along with are you letting the engine get up to full temp before giving it hell??
Old Sep 29, 2010 | 10:45 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Did you install the seats and seals that came with the kit?? if not, the inner springs will coil-bind at about .550" valve lift, and that will be the culprit of the broken springs! The issue is the O.D. of the one piece seat/seal that GM installed on the heads is too large for that inner spring, and it will not sit down fully on the seat, causing coil-bind very early.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 29, 2010 | 11:01 AM
yes i have the comp cam 1.72 rockers... and everything that came with the patriot kit was installed
im running factory valves in the ls6 heads
is it possible i gave the car to much hell right from the start?
im just gonna go with the comp cam dual valves
Old Sep 29, 2010 | 11:07 AM
How many broke? You could just throw a different kit on there, but it's always nice to know WHY something broke before you just replace it, IMO!
__________________
Old Sep 29, 2010 | 11:12 AM
Lambert695's Avatar
hmmm I have patriot golds with ls6 heads and no problem. So even if you change springs you might run into the same problem...
Old Sep 29, 2010 | 11:19 AM
incbed's Avatar
yes especially if they havn't went threw a few heat cycles also the 1.72 rockers push down on the springs more than 1.7 and you said your cam has a lift of 625 so you are at the max of the spring binding point with 1.72 rockers.
Old Sep 29, 2010 | 11:22 AM
at least 3-5 broke, im gunna try and take it easy for a lil while before i get on the car, im thinking my dumbass shoulda took it easy for a while
Old Sep 29, 2010 | 11:49 AM
vettenuts's Avatar
Taking it easy on them is not the answer. There is something wrong with the setup. The "lift" is only guidance at a specified installed height and in reality is meaningless. You need to find installed height, total lift, coil bind, etc. and determine how much clearance you have to bind, to the seal, etc.
What is your installed height?
If you didn't measure, you need to otherwise you are guessing and needlessly throwing money away.
Old Sep 29, 2010 | 11:58 AM
Actually, no. Even if the .625" lift was with a 1.7 rocker ratio, with the 1.72 rockers it is only .632" of valve lift.
THIS!!! There was another thread very recently where a guy checked the installed heights with that spring kit and they were quite a way off from the "norm" or assumed height! If he would have installed them blindly, he would have had similar issues!
__________________
Old Sep 29, 2010 | 12:08 PM
i honestly think its just not letting the cars temp heat up, and getting on it to fast i ordered the comp cam springs.
so my setup now will be
ls6 heads
comp cam pushrods (stock length)
comp cam 1.72 rocker arms gold
comp cam dual valve springs they were like 380 at ws6store..
with the comp cam.. Int. 243 Ext. 251 Lift Int. .624 Exh. .624 LSA 114° cam specs.
thanks god i check it out before i had the car dyno'd it was suppose to go today..
i mean i kno the cam is big, i just hope if i heat cycle everything right,
this will all work out for me.
Old Sep 29, 2010 | 12:31 PM
incbed's Avatar
Matt@Texas-Speed<<<< i'm not doubting your expertise ,but he is using the heavier 1.72 rocker arms along with revving the hell out of the engine wile it is still cold and as you know the valves are probly floating wile he is revving the hell out of the engine you just did a post on that issue,,,,so thats whay I said what I said ,because even though it may be 635 lift total ,but after the valves start floating who knows how much lift the springs are actually seeing and the springs are still cold on top of that.
I knew this idiot that was trying to show out to his nieghbor and started up his car cold and was revving the hell out of it and he broke two springs,,after he fixed the two springs and let the car get up to temp he hasn't broken a spring agian,,,and he's one of those guys thats revvs like crazy at any other fast car that he see's and to just show out.
Old Sep 29, 2010 | 01:09 PM
The LS6 heads had light weight sodium filled intake valves....even with a relatively heavy rocker and alot of RPM he should not have broken 3 inner springs just because he didn't let it warm up! I'm not a fan of that spring kit, but something else is wrong on this one.
__________________
Old Sep 29, 2010 | 01:15 PM
01ssreda4's Avatar
Only the vette heads had the sodium valves. He didn't actually specify thats what he had. I wouldn't be surprised if it was the non-sodium 243s or 799s.
Old Sep 29, 2010 | 01:18 PM
Originally Posted by 01ssreda4
Only the vette heads had the sodium valves. He didn't actually specify thats what he had. I wouldn't be surprised if it wasn't the non-sodium 243s or 799s.
True, and thanks for the correction. BUT, I would still bet against the not heating up first being the issue with a standard GM 2.00"/1.55" valve!
__________________
Old Sep 29, 2010 | 01:41 PM
Default ..
im using the stock valves out of my ls1 in the ls6 heads. i got the ls6 heads bear. um so im def letting the car warm up with these new comp cam spring kit.
Old Sep 29, 2010 | 03:23 PM
vettenuts's Avatar
One more time. If you blindly install valve spring without measuring you will be back asking why they are breaking again. I have not yet assembled a set of heads with stock parts that come out at 1.800", they are less and if you don't have the final height you are asking for problems.
Old Sep 29, 2010 | 04:26 PM
BIG_MIKE2005's Avatar
I'd also lean toward it being caused by something in the combo not running the springs cold. Granted thats not really a good idea but I have done it a time or two & my Patriot Golds are just fine 50k miles later.
I think its something in the combo most likely related to the aftermarket rocker ratio, pushrod length & lifter preload. But thats just my opinion. Honestly I refuse to run anything except a 1.7 rocker on these engines. If you want more lift go with a cam thats already got it & stick with the stock ratio rocker. Again, just my .02
