help with pushrod lenght and help to calculate compression
Old Oct 7, 2010 | 04:19 PM
droptopT/A's Avatar
Default help with pushrod lenght and help to calculate compression
hey guys i have a set of patriot stage 2 heads the ls6 style 035 casting with the 59 cc chambers i had to get them milled .006 cause they had some real minor scratches on the surface im also going to put ls7 lifters and im using the stock 5.7 gm mls gaskets.
is the .006 going to affect compression and ptv cleareance?
should i use a shorter pushrod i have 7.400 right now but im thinking of going with 7.300?
im going with a lg g5x1 cam 228/232 588/571 on a 114
i would really like to run a bigger cam but idunno if im going to have ptv cleareance issues
i like the street sweaper and the f14 but if u can recommend me a good one go for it lol
Old Oct 7, 2010 | 11:53 PM
SOMbitch's Avatar
You will have to measure PR length for sure...
I don't think the x1 will clear at 59cc either (unless they are the old welded chambers) so definitely measure that......
Old Oct 8, 2010 | 12:08 AM
01ssreda4's Avatar
035 casting isn't an ls6 head. The 243/799 are ls6 castings. You dont guess at pushrod length, you measure. Plain and simple.
Old Oct 8, 2010 | 02:52 AM
droptopT/A's Avatar
ls6 style " 035 castings i never said they were 243s
Old Oct 8, 2010 | 03:02 AM
droptopT/A's Avatar
yeah there the old welded ones im going to order the pushrod lenght checker tommorow from summit.how do i go about to checking the ptv im a newb sorry for all the questions i just dont want to blow my engine
Old Oct 8, 2010 | 03:03 AM
01ssreda4's Avatar
Im sorry What is an "LS6 style" exactly?
Old Oct 8, 2010 | 03:23 AM
droptopT/A's Avatar
its a 035 casting head that patriot runs a ls6 style desigh on.its not a ls6 head its a ls6 style" lol i just copied what was on patriots web site if it bothers u so much ill just edit my post.PATRIOT 035 STAGE 2 HEADS WITH 59CC CHAMBERS
Old Oct 8, 2010 | 03:26 AM
01ssreda4's Avatar
No don't edit it, I was trying to clarify what heads you were talking about. I'm guessing they are 5.3s. The more we know, the more we can help you
Old Oct 8, 2010 | 12:30 PM
droptopT/A's Avatar
bumpt to the top
any comments or suggestions
Old Oct 9, 2010 | 01:44 PM
droptopT/A's Avatar
bump
