Cam Help
Old Oct 12, 2010 | 09:27 AM
Midnight00SS's Avatar
Default Cam Help
I have 02 SS M6, with full exhaust and a lid, i daily drive the car, so i dont want anything crazy, but i would like to hear a nice lope, but something i can drive with, also do i have to change anything else with the cam? like springs or pushrods, or do they make a cam that u dont have to change anything?
Old Oct 12, 2010 | 12:18 PM
anyone?
Old Oct 12, 2010 | 12:31 PM
King Nothing's Avatar
i'm gonna go with a reverse split cam, check out the TR230/224 cam it makes good power, pulls hard from what i see on every post and has good drivability. you'll have to change springs and pushrods with any of the aftermarket cams
Old Oct 12, 2010 | 12:35 PM
bene's Avatar
Trunion King
Best bet is to either talk the vendors-sponsors who specs cam for your own needs or read the threads here and do your homework.
Old Oct 12, 2010 | 12:43 PM
thanks guys, im gonna check that cam out, also how much does it cost for the labor for the cam and springs and pushrods to be put in? anything else i would need?
Old Oct 12, 2010 | 12:57 PM
bene's Avatar
Trunion King
To tell you the truth, you can put this cam by yourself if you have the space and time to do it.
I have no, I mean no experience of putting a motor together much less putting a cam in any car but I did it. Granted I took my time and studied up on it before tackling this project. All in the end I got it done and the car is running good.
Old Oct 12, 2010 | 01:06 PM
I have no, I mean no experience of putting a motor engine together much less putting a cam in any car but I did it. Granted I took my time and studied up on it before tackling this project. All in the end I got it done and the car is running good.
no kidding, so im guessing theres not much labor cost to it? wut about the springs?
Old Oct 12, 2010 | 01:09 PM
TooLateVTEC's Avatar
The labor wont be cheap if your not doing it yourself. Its not how 'hard' the job is, its mostly the time b/c swapping the springs its very time consuming.
Since its a DD, I would recommend something like a 224 duration cam and a 228 at the max.
Your going to need to swap springs and pushrods with any camshaft swap. Since you have a stick, better start saving up for an aftermarket clutch as well.
Old Oct 12, 2010 | 01:10 PM
bene's Avatar
Trunion King
Upgrade your valve springs for any cam swap, at the minimum Comp 918s or PAC brand for a small cam, bigger cam go with dual valve spring set up.
Old Oct 12, 2010 | 10:08 PM
yea i wanna hear a nice lope to it, how much labor wise do u think it would cost?
Old Oct 13, 2010 | 06:37 AM
garygnu's Avatar
consider a TSP cam pkg,224r/228r at 112*lsa.or a tr224 at 112*lsa.I've heard $700-900 for install labor.go to ls1howto.com and see if you and a friend mite do the install.you will need a tune up for the new cam.
Old Oct 13, 2010 | 12:29 PM
cool thats for everyhing springs on heads and cam and lifters pushrods?
Old Oct 14, 2010 | 12:36 AM
do u have to up ur injector size at all with any of these cams?
Old Oct 14, 2010 | 06:44 AM
garygnu's Avatar
you have #28 injectors you will be ok with them.
Old Oct 14, 2010 | 07:42 AM
Kaltech Tuning's Avatar
Give me a call, I'll get you setup.
Old Oct 14, 2010 | 11:53 AM
ok sounds good i will
