needs mo' power...best way to do this?
but what is the best/easy/cheapest way to do this?
#1 i have been looking into gettin a sts kit
there site says at 5psi stock cars put down 405hp
i found a few used kits for around $2000 give or take a $200
plus what ever the fuel system cost...plus i love the sound of a turbo
and it would replace the exhaust so it will save me some $$$ there
#2 heads and cam package or just a cam
can i get into the 400hp range with just a cam??? and other mods, exhaust and such?
or will i need to get a head and cam combo along with full exhaust
i have not looked into pricing on this option
anything will help guys
this is my DD i wanna keep the ac and everything...
also i wanna stay away from nitrous i would like to have the power with out filling a bottle every time i wanna stomp on it...
also what kind of track times should i see?
thanks
thanks
You can make 400 rwhp with a cam only and some headers but you'll probably have to swap your rear gears because the cam is going to be peaky with lots of lope not exactly what some people would like to drive on a commute to work. The H/C will get you there easily, again the cam you chose is going to determine the driveability.
Any of these mods is going to affect your fuel mileage, so I would think about this on a daily driver.
if lower 400hp can happen with just a cam and bolt ons ill probably go that way...
but will the cam still be streetable...not realy worried about mpg, i have a truck i can drive i just want it to be streetable when i do drive the car
what are some of the cams yall have seen that put out some good hp numbers and are streetable at the same time?
what are some of the cams yall have seen what put out some good hp numbers and are streetable at the same time?
Cam will have to be around 234-242 duration and .600 lift though.
