Tick noise after cam and head install
Its usually the tougher springs that require a hardened pushrod not a cam.
Think about it, the distance it travels is not going to affect the structure of the rod, the pressure is a different matter though. I already used tougher springs with stock push rods and didn't have an issue.
Please correct me if I am wrong but I don't like to upgrade because someone trolling wanted to put in their 2 cents without data to provide.
STOP TROLLING
Makes sense send the expansion and compression of the metal. I think personally since I used thread lock on the intake rocker bolts I should just do so with the exhaust bolts as well.
He says the can support up to .620 lift and said the xer251hr cam was a great fit for my head setup.
I asked about the rods and rocker arms, he said unless I already have an issue or if I throw nitrous on top of it to leave them as is.
224/230 duration
581/592 lift
114 LSA
also did comp cam 918 beehive springs
chrome moly stock length push rods
I did scorpion roller rockers. They are really nice and I really like them.
http://www.youtube.com/watch?v=dyZq0sh-bh8
224/230 duration
581/592 lift
114 LSA
Good to hear your data. I think I will do the same thing with roller rockers and pushrods. Thanks!
I have heard on the converse side of this though that the trunion upgrade is what prevents the bearings from exploding into your upper area of the head. One other commented that he just tack welded the trunion bearing to ensure it couldn't come out the side. So what we are seeing is probably normal its just that when real high horse power is added to some old rocker bearings you might get them to pop right out.
Thoughts anyone?
Check ur lash and then please order some good push rods.
For inquiring minds, I found this on the net in several places (so makes it true right
) that the tollerance for preload on stock ls1 lifters is .020 to .060. So that is why you see .050 as a preload amount to add to your push rod check.Scorpion recommends to not add preload because of clearance issues. But if you do a piston to valve clearance check then it is a-ok to add preload. I personally had to fly cut my pistons to do this.
BTW lindytools.com is the best solution for flycutting your own pistons at home! Great guy to call up and ask some questions too about the process. Very helpful!
