Sounds Like a Rod Knocking
Old Oct 23, 2010 | 08:14 PM
Nitro_Junkie's Avatar
Default Sounds Like a Rod Knocking
Here's the setup: Stock 2001 Vette, 133k miles (not a garage queen). Car was running fine. Stopped for gas and afterwards, it wouldn't start. Good battery, but no crank, no push start. Had it towed home on a flatbed.
Pulled codes and got the Passkey code (B2723). On my kids F-bodies, I had the same issue, and was able to bypass the pellet with a resistor of the same value, so I tried this with the Vette. Started right up, but now there is a knocking that sounds like a rod. Was not knocking before the tow. Oil pressure is at 50+ pounds. Could the tow have caused an issue, or is it just coincidence?
Thanks
Old Oct 23, 2010 | 08:31 PM
HotSilverBird's Avatar
Is this a joke?
Old Oct 23, 2010 | 08:40 PM
Are you a dick? No, its not a joke. The rod was not knocking prior to having it towed. I was thinking maybe the oil in the pan got trapped behind a baffle when the car was going up the ramp. I would appreciate a educated response from someone, not sarcasm. I joined this forum to get assistance from educated people, not wisecracks from keyboard crewchiefs.
Old Oct 23, 2010 | 08:44 PM
You think having your car towed has caused it to have a rod knock? SERIOUSLY think about what you are asking............
Old Oct 23, 2010 | 08:55 PM
The rod was not knocking when I stopped for gas. The car has easy miles on it, mostly under 2000 RPM. I see no reason why the rod would start knocking after being towed either, but something made it start.
Old Oct 23, 2010 | 08:56 PM
Maybe the tow truck driver was racing your car in his mind and over revved it? LMAO
Sorry dood but this is some crazy post!
Old Oct 23, 2010 | 09:01 PM
Maybe a piece of carbon broke off and is causing a knock, I had this happen after a body shop worked on my car for a week. Went away after a few miles but it did scare me and i was kinda uset with the body shop.
Old Oct 23, 2010 | 09:02 PM
Old Oct 23, 2010 | 09:06 PM
If you drive your car easy all the time it will build up some serious carbon on the pistons. If a piece breaks off it will knock like hell. DO THIS....take the car out for a drive and run it hard, If its carbon it will clear up. If its a rod bearing it will just get worse quickly. You got NOTHING to lose and everything to gain and listen RELAX!
Old Oct 23, 2010 | 09:52 PM
blsnelling's Avatar
If it throws a rod, he's got a LOT to loose.
Old Oct 23, 2010 | 10:07 PM
projectX's Avatar
I would have it checked by a mechanic and get a diagnostic test ran. Hope it helps and welcome to forum.
Old Oct 24, 2010 | 02:39 AM
Well I didn't tell him to beat the snot out of it. If its got 50 psi oil pressure I SERIOUSLY doubt hes tossing a rod any time soon..................
Old Oct 24, 2010 | 09:50 AM
Thanks for the replies. So I'm thinking that with 133k miles, I should go ahead and replace all of the rod bearings, wrist pin bushings, and timing chain. What about mains? Can I do this without removing the engine from the car?
Old Oct 24, 2010 | 10:53 AM
Tommyv8's Avatar
My car has over 200k miles and runs pretty much tip-top, valve covers have never been lifted. So as long as it's been properly maintained then I don't think that high mileage has anything to do with your problem.
This may be a stupid question, but have you checked to see if anything may have gotten too close to the fan? How rapid is the knocking?
Old Oct 24, 2010 | 11:00 AM
bene's Avatar
Trunion King
Can you post a vid of this rod knock noise?
To post this problem and diagnose/troubleshoot is kinda of a crap shoot, shot in the dark IMO.
It might be as simple as a bad batch of gas you got from the gas station.
Old Oct 24, 2010 | 12:33 PM
Just cranked it to take a video and it is not knocking any more. Still has a code C1214.
Old Oct 24, 2010 | 12:48 PM
KevinR's Avatar
So let me get this straight...If I have a knock, I should take my car out and drive it hard, and hope it clears up?? Great advice. And you are asking the OP if he is serious??
Old Oct 24, 2010 | 01:43 PM
yeah no ****! dick tracy...it aint knocking no more is it???? so I aint so ****** stupid am I ????? he knocked a piece of carbon loose...happens to people all the time that baby these cars........
anyone else wanna take me on bring it!
Old Oct 24, 2010 | 01:45 PM
blsnelling's Avatar
The fact that it's not knocking now, has no bearing on the wisdom, or lack there of, of your suggestion.
Old Oct 24, 2010 | 01:49 PM
I knew you didn't have a rod knock....geez
I've been doing this a very long time. I've bought vehicles at auction that had engine knocks. Standard test is take um for a hard drive...either gonna get worse or alot better if its carbon. I've seen MANY MANY new engines tore down and cranks and bearing replaced because of carbon knocks.....it so freakin common...BUT I DON"T KNOW ****!
