ready to start but will it run?
Old Oct 25, 2010 | 01:38 PM
260B4U's Avatar
Default ready to start but will it run?
just completed the heads and cams swap with 38 lb injectors ready to start
afr 205's
tsp 228R
38lb injectors
will it start on stock tune ?
Old Oct 25, 2010 | 01:48 PM
Darkman's Avatar
You should start it with whatever injectors it is tuned for. In fact, an injector change should not be done until you are with the tuner.
Old Oct 25, 2010 | 02:29 PM
blsnelling's Avatar
+1. I would not try to start it if you have changed the injector size.
Old Oct 25, 2010 | 03:37 PM
260B4U's Avatar
will it run well enough with stock injectors to take it to the tuner? or will it be really lean i have plx widebands for each cylinder bank
Old Oct 25, 2010 | 03:49 PM
Rise of the Phoenix's Avatar
I'd like to know this as well. Is replacing the stock injectors a must when doing a heads/cam swap? I'm about to do mine and hadn't planned on injectors.
Old Oct 25, 2010 | 03:54 PM
180ls1's Avatar
yea put the stock injectors back on there or have your tuner calibrate the computer for the larger injectors. The last thing you want to do is kill your rings because of too much fuel and you will do that.
To get it to idle better i would adjust that screw on your throttle body.
Old Oct 25, 2010 | 04:10 PM
vettenuts's Avatar
I drove to the tuners with stock injectors and changed when I got there. He did an initial tune for the restart with larger injectors. I agree with all above.
Old Oct 25, 2010 | 04:30 PM
Jon@Texas-Speed's Avatar
Don't start it with untuned injectors. If anything leave the stock ones in and swap them when you get it tuned. It will be okay to drive a bit untuned otherwise. You might have to help it stay idling though. But don't run it with the new injectors until you get it tuned unless you plan on putting rings in it.
Jon
Old Oct 25, 2010 | 04:55 PM
260B4U's Avatar
cool thanks for the info guys
Old Oct 25, 2010 | 10:42 PM
260B4U's Avatar
all right pressures up wow it is way louder then before... my neighbors will love it
Old Oct 26, 2010 | 12:07 AM
01ssreda4's Avatar
Exactly, you dont want to start an engine without the right injector scaling in the computer.
Old Oct 26, 2010 | 03:18 PM
rob00ss's Avatar
how long would it take to ruin ur rings with untuned injectors
