how long till it ruins ur rings
#41
My car has a cam so I doubt id tell a difference/slight miss at idle. It deff doesn't have a misfire at all while driving. It sucks thinking I could be losing some power/performance from such a stupid thing. Id say its fine though I'm sure people have drove on engines with misfires before longer then an hour before without issues.
#42
Lean and rich are relative to A/F ratio, so if there is no F in the A/F ratio how can it be lean?
since there is no fuel on that cylinder, your only getting air...fresh air introduced into an exhaust system with 3 correctly operating cylinders spent gasses causes a lean condition...use your head.
#43
ok, ill explain this to you once...the O2 monitors one bank, that includes 4 cylinders...if one injector shuts down, there is no fuel on that cylinder. however, there is still air because the piston and valves are still letting fresh air in to be "burnt". guess where that fresh air goes...right out the exhaust past the O2 sensor causing a lean condition. end of story.
this makes me giggle...
#44
btw i also quoted you where you said "if there is no F in the A/F how can it be lean or rich?" well nobody cares if each cylinder is rich or not, if the O2 is doing its job it will compensate.
#45
who gives a **** about the cylinder????? the o2 does not monitor each cylinder. one dead hole will cause a lean condition.
And yeah you did quote me on the A/F comment, and my point still stands the A/F of that cylinder is what is being spoken about, when did I ever say anything about a bank or an 02 sensor? You are looking at it like I was having a conversation about 02 sensors, fuel trims, or rich/lean conditions on a particular bank, I wasn't.
Does it click yet?????
#46
Mines a stick car I pulled two different wires and the computer bumped up the idle so neither one made much of a difference at idle I couldn't really tell anything from that test
#47
[quote=00pooterSS;14058826]
First you suck at quoting
I will agree with you on this one.
Wow a misfire is not always an engine miss is that hard for you to understand?
You are just playing bullshit word games here. You cant stop the pcm from compensating for then lean condition no matter how you word it. It will effect the whole bank.
Third, you and phenomic keep saying misfire and running "perfectly" fine in the same sentance, not possible, never will be, misfire cannot equal running perfectly fine... Is that really that hard to understand?
So you are saying a cylinder that is burning no fuel what so ever will be burning lean? You cannot burn lean nor rich if there is no fuel present so please explain that to me....
#49
[QUOTE=BaddBird;14059209]
You are just playing bullshit word games here. You cant stop the pcm from compensating for then lean condition no matter how you word it. It will effect the whole bank. Hold on getting note pad, note to self: an engine misfire is not always an engine misfire. Got it!
And no, its not hard to understand but I would like you to point out where you have stated in this thread that there was something other than a misfire that was a misfire that I didn't understand...
Im assuming with that comment you are talking about something to the tune of how exhaust hitting the body of the car can cause false knock? Nope never heard of anything like that at all.
IWGF, Thank you sir, it was getting a bit tiring!
#51
[quote=00pooterSS;14059416]
Hold on getting note pad, note to self: an engine misfire is not always an engine MISS. Got it!
I'm going to make this short. Example P0300 throw a scan tool on the vehicle shows random misfires but the car has no miss. Only complaint is the Cel. There is a reflash update for the pcm to guess what? raise the threshold for the misfire counter. Re flash the pcm and guess what car still runs perfect and no Cel. Just one of many ways you can have a "misfire" and the engine run perfect as in no engine miss. If you are a dealer tech for those glorified Toyota's in a Lexus wrappers then you should be well aware of the keep the light out till the warranty is up game they play with the software updates. That is unless you are to busy zip tying floor mats and installing washers on the accelerator pedals. I do have a note for your note pad if you want any more info from me your going to have to give me a credit card # because I'm done schooling you for free.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
#52
[QUOTE=BaddBird;14059809]
LOL that was pretty good, i'll have to give you that. But im gonna keep the card number man. I understand what you are saying about the threshold, its kinda like when Ford had an issues around 10 or so years ago with getting a CEL for misfire caused by rough roads and had to raise the threshold and now on the trucks especially the PCM will barely even pick up an actual misfire.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
