12:1 Compression in LQ9
Old Oct 27, 2010 | 03:09 PM
blade7022's Avatar
Default 12:1 Compression in LQ9
Has/is anyone run 12:1 in a LQ9? Is it possible. I know -3 dish pistons yeild a low to mid 11 with the 71cc compustion chamber. I guess the quesion is, is it ok to put a +5 dome piston in a LQ9 with the 317 heads?
Thanks for any input.
Old Oct 27, 2010 | 03:11 PM
blsnelling's Avatar
What are you going to run for fuel?
Old Oct 27, 2010 | 03:17 PM
blade7022's Avatar
We get up to 91 here.
Old Oct 27, 2010 | 03:20 PM
blsnelling's Avatar
I think you're going to have issues with that much compression on 91 octane fuel. I have to let those more experienced step in here.
Old Oct 27, 2010 | 03:23 PM
blade7022's Avatar
Talking
Thanks for the input, I am aware that if I do go that high I will need to buy stock in octane booser !!!
Old Oct 27, 2010 | 03:29 PM
bww3588's Avatar
if you could get 93, it might be a different story. everyone i talked to said 12:1 will be fine with the correct (read perfect) tune on 93. and if i really wanna go wild with the timing, i got a good supply line on VP MS109.
Old Oct 27, 2010 | 03:50 PM
blade7022's Avatar
Thats what I was thinking, 93 is VERY doable. Not quite ready for the race fuel however LOL!!!!
Old Oct 27, 2010 | 03:57 PM
bww3588's Avatar
may be a little safer to go with 11.75:1 not gonna be a huge power difference and will be a little bit more forgiving if you have a lean spike or a timing issue.
