TFS 220 as cast heads question.
1. do the rocker arm bolts go into the ports on these heads.
2. would just a value seal smoke that bad.
3. how would i tell if the valve guides where the wrong size and sucking oil with out pulling the heads?
If anyone has had this problem please enlighten me. I had these heads installed at a shop and he doesn't believe the rocker bolts go into the ports on these heads. He thinks it's the valve seals. I have put around 500 miles on the heads, cam & intake install since June.
hopefully it is that simple I'll report what the results are as soon as I can get the work done.
