Carbed LQ4/L92/Vic Jr/cam
Posted this already in the carbed section but thought it would get more views here...
224/232 on 109+1
10 degrees of overlap so it should have a nice hard hittin exhaust note. This should make it peak around 6000ish (40* IVC)and carry til shift point at 6300 and still have good midrange torque since the EVO is 46*. IVO and IVC are pretty close at 4* and 6*. Keep in mind this will be in a 4klb street car.
Opinions?
224/232 on 109+1
Opinions?
i got ly6 rotating parts in a GMPP 6.0L block (so i didnt have to change my harness) .070" milles l92's with a level one port work(polished runners, with more bowl work than anything) GMPP L92 intake(not as good as a victor jr) ultra low profile elbow, bullet custom grind cam 24x 24x 6xx 6xx 107lsa cam. PBM High rev lifters, stock rockers. It rev's to the moon(peak was 7500) and made power all the way to 8k where we could tune it any higher.
anyways it made 6xx at the flywheel, and has taken my 3820lb 6 speed car to 10.93 at 126 NA, 1.44 60ft.
so I personally think your cam is to small to make as much power as it can, but you didnt really say what you wanted to do with it....??
