getting a cheatR cam..which heads?
Old Nov 8, 2010 | 07:53 PM
408Maro's Avatar
Default getting a cheatR cam..which heads?
hey guys I made a thread about getting 400rwhp that'll pass cali smog on stock manifolds and cats with just a UD Pulley,4.10s.Lid,Cutout,racetronix pump,and greentops as my only mods on a 01 6speed z..so decided im going with either a cheatr v3 cam or even a eps cam with similar specs..specs of the cheatr is 219/230 .607/.604 on 117
so now that i know pretty much which cam im going with which heads should i get that'll benefit me more? im getting a stock casting head and my options are my 241's,or 706's,853's and if i can 799's..which would be best with this cam,stock or not on the heads is both possible..thanks
John
Old Nov 8, 2010 | 11:00 PM
01 Bad Mutha F*****'s Avatar
The classic match from Thunder has been the AFR 205's which by the way are emissions legal.
Old Nov 9, 2010 | 08:13 AM
408Maro's Avatar
Yea good match but to much for me
Old Nov 9, 2010 | 09:19 AM
kinglt-1's Avatar
send your 241's to advanced induction... will net you around 40whp for 1100.00, or texas speed has the prc 2.5 5.3 heads for 1309.00 and that includes .650 lift springs.
Old Nov 9, 2010 | 09:25 AM
disc0monkey's Avatar
from my experience, you won't hit 400whp without a top of the line head like AFRs and to get you over possibly a FAST intake. If your on a budget, get cnc'd 243s and you'll get pretty close, but i would bet the farm you won't get 400. If you want less noise get the eps with beehives.
Old Nov 9, 2010 | 09:34 AM
408Maro's Avatar
Thanks I can get 706 heads for damn near nothing from a friend and send them to a local spot aswell as my 241's. It's between either of those 2..which of those 2 would be better? I'm going to disagree with you on having to have a top of the line head to get 400 though
kinglt-1's Avatar
I think the 706 heads are slightly better than the 241 when the are fully ported w/ bigger valves installed. the smaller combustion chambers bumps compression up also.
Old Nov 9, 2010 | 09:43 AM
thats fine, wish you all the luck to meet your goal. personally in that setup since its not a ***** out setup i think theres more value in cncing a stock head. if you do your research you'll see hitting the 400 mark with that cam is quite an accomplishment, and investment.
Old Nov 9, 2010 | 09:52 AM
408Maro's Avatar
No worries and thanks. I just seen a few threads with this cam and similar spec'd cams with stage 2.5 5.3's make 403 or 406 rwhp so I know its possible. I just want to use either the 241 or 706 head. Which ever would be best for my setup. If I don't hit the 400 as long as I'm close I'm happy. Thanks
John
Old Nov 9, 2010 | 10:01 AM
you'll def be close and trust me its a fun setup, and i dont even have 4.10s yet. just some ppl get hung up on a number and if they make 399 they'll be disappointed. just remember your 4.10s will gobble up 10hp. ive seen some 400+ setups having headers but i havent seen any 400+ other than patrick's with stock exhaust.
Old Nov 9, 2010 | 10:13 AM
408Maro's Avatar
Thanks man yea don't care about the numbers. Just want her to move and surprise people haha.
Old Nov 9, 2010 | 11:37 AM
King Nothing's Avatar
hey john, talk to Geoff and PatrickG about specing you out a custom one at EPS
Old Nov 9, 2010 | 11:48 AM
408Maro's Avatar
Thanks john I may just do that
Old Nov 9, 2010 | 12:53 PM
Rise of the Phoenix's Avatar
Look in the classifieds section on here for some used TFS or AFR heads. Heads really need to be the center and most important part of you build. Buy the best heads and then go from there.
Old Nov 9, 2010 | 01:29 PM
408Maro's Avatar
Has to be a stock style head to pass smog and even used afr heads with a CARB number still too much for me
Old Nov 10, 2010 | 05:16 PM
408Maro's Avatar
Up top please
Old Nov 10, 2010 | 05:19 PM
River City Speed's Avatar
If you can swing it, 243 or 799 heads. I just bought a set of 799 heads local for $350. That was cheaper than the cam. BTW, you may have seen my thread below. CheaTR cam and 799 heads. The motor isn't done yet but the few people that replied seem to think 400rwhp is doable.
Old Nov 11, 2010 | 09:34 AM
408Maro's Avatar
Thanks guys. I'll forsure repost once I know which heads I'm going with forsure and once its finally done
Old Nov 12, 2010 | 03:47 PM
ugotsmoked's Avatar
i'm running a cheatr cam v.3 with stock ls6 heads and full boltons and im only making about 370rwhp 370rwtq but the torque curve is flat and fun to drive though.
Old Nov 12, 2010 | 08:36 PM
408Maro's Avatar
Nice 370/370 is good numbers for a small.cam and bet it moves
