does tsp make crap cams ?
Old Dec 8, 2010 | 12:12 AM
joblo1978's Avatar
Most vendors outsource their cams anyway, most are comp.
TSP only holds the stock bottom end LS1 record. Hardly crap.
Old Dec 8, 2010 | 12:52 AM
usafws6's Avatar
first let me say that i really enjoy my tsp torquer v2, but for a daily driver 80 miles a day i might go with a smaller cam. maybe a 224r ground on 112. itll save you some gas. lol.
Old Dec 8, 2010 | 01:25 AM
GT_EATR's Avatar
I have the TSP MS3 package with hardened pushrods and double valve springs...stock heads with and LS6 intake and my 98 Z28 is a beast... TSP is definately on top of their game...But you get what you order so i dnt see how TSP is to blame for anything..You have to custom order your parts... so its actually exactly what u want everytime.
Old Dec 8, 2010 | 05:48 AM
mark97ta's Avatar
thanks alot guys... I guess i'll go with the 228r and really look at my valve train geometry when i put it all together. I prob would have taken it for granted :-(
Old Dec 8, 2010 | 05:57 AM
venom ws7's Avatar
I've been dealing with TSP for over 5 years and bought over 50 cams from them
NEVER had a single problem.....
Old Dec 8, 2010 | 06:35 AM
BOBS99SS's Avatar
Captain Double Post
That guy is a moron and I would have someone else tune my car,a guy that will tell you a great package is junk just so he could sell his kit is shady imo,I have bought almost all my stuff threw tsp there prices are always the best and there stuff is top notch,and any time I had a question or needed some helpful advice I know I can always call them ,even if I didn't buy the part from them,they would still take there time to help me out,when I was trying to pick a cam I called them at least 3 times and they talked with me for over an hour about what would be best,I got the ms4 cam kit,and I could not be more happy with the cam and the kit,that guy wouldn't be touching my car ,that's just real shady imho
Old Dec 8, 2010 | 06:41 AM
garygnu's Avatar
what stall are you using? go to ls1howto.com for instruction for a cam install.
Gordon0652's Avatar
Originally Posted by 01ssreda4
TSP is a well respected vendor here.
Exactly.
Old Dec 8, 2010 | 08:22 AM
NC98Z's Avatar
The cams that TSP sells are ground by Competion Cams. So I guess your asking does Comp Cams have a problem? When they do they Comp Cams will stand behind their product and replace any defective cam that got sent out defective. As far as TSP goes they built the longblock I'm running now and it has been run hard for 2 years now with out any problems. Its in a full weight Camaro with a 300+ pound driver running 11.28s@119mph thats daily driven to work as long as the weather permits. TSP also put their cams and heads combinations on their Dyno and posted up the results for the world to see. And people who sell junk usually don't do too much advertising do they? Now If you want some junk go buy you one of them reground EBAY specials.
Old Dec 8, 2010 | 08:23 AM
396D1SS's Avatar
I think you need to find a new tuner
Old Dec 8, 2010 | 08:36 AM
Z06 Steve's Avatar
your friend
TSP
Old Dec 8, 2010 | 08:47 AM
  #32
skimms98's Avatar
^ This X eleventy billion...the guy obviously has an agenda.
I've bought multiple times from TSP over the years and have had ZERO issues.
TSP
Old Dec 8, 2010 | 09:02 AM
  #33
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
LOL! This is a pretty funny post!
It never surprises me when someone makes crazy statements to make their products look better.
Here's the deal we do complete engine dyno testing on the camshafts combinations we put together & sell. I don't think anyone else on all of ls1tech does anything near the testing we do on LS engines building camshafts/cylinder head combos..
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 8, 2010 | 09:06 AM
  #34
Jon@Texas-Speed's Avatar
Who is your tuner? Eastern NC?
Old Dec 8, 2010 | 09:23 AM
  #35
Originally Posted by 2002silverz28matt
my tsp cam lobes started to come apart, possibly a bad core, however just found out my prc ls6 heads had different lenght valve guides installed, now i have valve guide wear, rocker wear, and valve wear. You can feel the play in the valve. I thought it was the motor eating oil, turns out it was the heads. i will never buy anything from tsp again
I don't mean to be negative but every TSP GM ported head has FACTORY GM guides in them. Every casting is brand new. They absolutely do NOT have different length guides in them. If the cam had a bad core, we could have more than likely got it replaced with Comp. A simple phone call would have more than likely got it resolved.
Jon
Old Dec 8, 2010 | 09:30 AM
  #36
JFOLM's Avatar
Some people do not want to call the vendor after something goes bad. They just will chunk the cam and give the company they bought it from a bad name. Regardless of who did the grind.
Old Dec 8, 2010 | 10:42 AM
  #37
2002silverz28matt's Avatar
Jon
I did call about the cam, that was roughly six months ago, it was caught when the 346 was swapped for a 383 and the only other damage done was to the lifters obviosly. The heads were just pulled yesterday by the shop. I am heading down there this afternoon to take a look and get some pictures. This issue was caught b/c I was just going to have the springs changed out. When the valve covers were pulled, thats when the rocker/valve wear was discovered. When the heads were pulled, thats when the guide lenght was discovered. I ended up going with a new set of TEA TFS b/c the machine work would cost a fortune to install new guides in the heads and I needed rockers anyway. I agree, the heads SHOULD have GM guides in them and they all SHOULD be the same lenght. Like I said, I will have pics very soon.
Old Dec 8, 2010 | 07:00 PM
  #38
BOBS99SS's Avatar
Captain Double Post
I know if I ever had a problem with tsp all I would have to do is call,its that easy,like I stated before there customer service is great,2002silver,what did they say when you called,I don't know why you would leave that part out?
Old Dec 8, 2010 | 07:07 PM
  #39
mark97ta's Avatar
Yes I live in eastern NC, and I don't know if I should say his name or not but his shop is in Vanceboro and his first name is William. I actually talked to someone at tsp today and he took plenty of time to answer all my questions and was helpful and sold me on a 228r.
Old Dec 8, 2010 | 07:08 PM
  #40
BOBS99SS's Avatar
Captain Double Post
Ok you called 6 months ago but the heads were pulled yesterday,is it just me or am I missing something here,I'm 100% positive if something was wrong with anything you got from them they would fix it,Jfolm I agree with you totally
