Should I rebearing a motor while I'm changing rod bolts?
I have an 02 motor with 80K miles on it with a 232/234 cam and ls6 heads. I plan on upgrading the rod bolts but while I'm in there should I replace the main bearings? Also what rod bolts should I go with? Btw, oil pressure is great on the motor, so the bearings are still good.
02 already has the upgraded rod bolts. I wouldn't suggest just throwing new bearings in there. Are you talking about pulling the motor and having it freshened or what?
If you're ging to pull the bearing why not at least get the crank polished and checked at an engine shop. If not I say leave them in there and just get the oil sampled every oil change and see what the wear is on the engine.
I honestly wouldn't even bother at 80K but thats just me and it's not my engine.
i just did my rod bolts. i used katech as they are designed for no resizing the rods. but mine is a 98 with 148k. i also did it in the car with the kmemeber dropped. i feel better now. i see 6.5k shifts everyonce in a while but the car is not my dd
