Oil pressure 101
No rod knock but definite valve train noise, motor is from internet supplier in Florida supposedly low mile. Internally looked clean and fresh. After grazing the forum for a few hours tonight I see a few oil pressure threads and some talk of oil pump/bypass valve failure. I am unfamiliar with this particular engine platform from a hands on experience standpoint and welcome any suggestions before I begin the obligtory snoop and poop deduction of possibilities. Thanks in advance.
Welcome to LS1 tech!
Here's where we're at now, dropped the pan and after looking at lubrication flow chart we blew compressed air into the pressure port (rearmost) on the block and the pressure bleeds into the forward port. Not srtaight through but there's definitely some leakage in what I'm assuming is a by pass valve. Not sure how big an issue this is, primarily wanted to look at bearings to see if there was damage. Thank God they look fine. Oil was darker than I'd like with some metallic residue. Where is the most likely early oil starvation failure bound to occur? Thanks
Ordered it (small town) first thing this morning, I should have paid closer attention when my helper swapped the parts over. Especially in that area!
Experience is a hell of a teacher.
. When you get your new o-ring lube the **** out of it so this doesnt happen, be very careful as you will be able to see the pickup sit flush on the pump. Don't overtighten that bolt either, it strips easy.
The Melling 10296 is a high pressure/high volume unit BTW. Be careful as the high volume units can suck the pan dry during sustained high rpm runs.Car is one app, truck is the other. The pick-up tubes are different sizes, thats the reason for the different thickness of o rings.
