Meziere LS1 Electric Water Pump
Hi fellas , Happy new year , my cousin installed the EWP on his 2000 Camaro , and he asked me how to install the belt and i don't know how ! because when he installed the belt it runs from Tensioner to EWP then underdrive pulley then to Alternator is this correct ?
can you guys please post pictures to see how it runs
thanks in advance
thanks in advance
Edit: See also http://www.ls1howto.com/index.php?article=26
If he has the 319 or street model then yes he needs to use the stock belt length and route the belt the same way it came off, the diagram above should be the same for the 2000's. They use to also make a "race" version as well, which did not have the pulley and required a different belt. The pulley on the pump is just free wheeling just like any other idler pulley in a serpentine belt setup.
is a shop doing the install? or are you doing it at your house?
most shops, i hope, would know how to route the belt.
but as states before if your using a pump that looks like this
http://www.byunspeed.com/images/MEZWP319R.jpg
then you would route the belt as you would if it was stock
