My New Prc heads are In. Dyno Numbers Inside Finally!!!
#64
Stock rockers have their needle bearings exposed, which mean in an event of a rocker failure, the bearings can be spit out of them and through your motor. These have them sealed up with no chance of them going in your motor. And they can take more abuse.
#67
Your build is coming along nice.
I'll be ordering from my H/C from TSP as soon as I get my tax money back. Still torn between 5.3/LS6's and tsunami/ms3. Have you ran into any issues or has it been pretty straight forward? Keep the pic's coming too!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#68
Have ran into zero issues so far. Honestly, anyone who tells you this is hard work is lying. Its not complicated work at all, its just time consuming. A lot of things need done, that is all. I'm going on 2 months with my car looking like this. But I'm taking my time and not rushing anything. MY car is down for winter so why the hell would I rush.
#71
Well my first initial plans were to get rid of the pcv system competely because I got new valve covers that do not have pcv connections, but I keep hearing thats not a good idea on a street car. I was just going to install breathers on the valve covers, but I'm not to sure if this is a good idea. I'm really not that familiar with the ls6 valley cover, how does it work?
Even down here in humid south Florida, no buildup of moisture.
All you need to do is what I did. Use an adjustable needle valve. It only has to suck a tiny little bit. Keep the PCV valve in line too. Just put a breather on the drivers side valve cover and suck crankcase gases from the passengers side valve cover....into the vacuum port on the intake. It will allow fresh air to travel across the entire crankcase. Cap off the upper TB port and the valley cover port (if you have one).
#73
The lifters were not shimmed solid. After a few other tries it seems that I need a 7.350 pushrod instead of a 7.325. I tightened the rock down to 22ftlbs with the push rod installed but not touching the rocker. I fit my fingers in there and managed to adjust the pushrod until it would not spin anymore. I then took the pushrod out and it is a tad bit more then 9 turns until it is closed.
#75
I also initially ran a 7.325 pushrod (only wanted .050" preload), then soon swapped to 7.350 because 7.325 wasn't offered in the thicker diameter I wanted.
7.350 may seem shorter than what is commonly discussed on tech', but that doesn't mean **** with regard to your build. As long as you're finding the exact point of zero lash while the lifters are on the cam's base circle, you've measured correctly. Add appropriate length for preload and you're good to go.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#79
LS1Tech Premium Sponsor
We had a completely stock long-block 2001 LS1 (stock rockers, stock short-block, heads had never been off, etc) in here for a cam install a month or so ago...it was simple XER lobes on both sides. It ended up needing 7.350" to get right about .070" preload! Everybody on this forum and their dogs told the guy to order 7.400" pushrods, minus a few of us who said to measure. He ended up having to send the pushrods he had ordered back for a refund (bought them from another vendor here that also swore 7.400" was the right length) and luckily we had the 7.350" in stock!
I'm glad you've measured. I think your measuring procedure is sound, and I would go 7.325" myself. But you'd likely be just fine at 7.350" (.100" preload) as well!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#80
I'm also gonna re check piston to valve clearence. The heads are now bolted on the engine so I'm gonna have to use a degree wheel. Can anyone tell me if this is the correct kit? Or do all kits work? http://www.summitracing.com/parts/TFS-90000/
![](http://i142.photobucket.com/albums/r108/iraclis/tfs-90000_w.jpg)
Also, would this tool work just fine in removing valve springs?
![](http://i142.photobucket.com/albums/r108/iraclis/crn-99472-1_w.jpg)
