Gains from TR230
Old Jan 17, 2011 | 12:10 AM
PACKERSz28Camaro's Avatar
Default Gains from TR230
Ok, so I have some pretty big plans for my car come spring. My car is basically stock except for an slp air lid.
What kind of HP increase will I see on my 2000z with a TR230/224 .575 .563 111 lsa, 1 3/4 longtubes, custom Y with flowmaster merge, SLP LM 2 exhaust, ported throttle body and street tune. Is 375 rear wheel about right? Just trying to get a ballpark of what I should expect.
Old Jan 17, 2011 | 12:12 AM
Also wanted to mention that the LS6 intake will be purchased but not right away.
Old Jan 17, 2011 | 12:32 AM
Squirts11's Avatar
M6 or auto? What gears and/or stall?
Old Jan 17, 2011 | 12:43 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you shooting for a certain number? Or looking for a quicker E/T?
Not sure if you know this yet, but that 230/224 is a reverse split cam. People have made decent power with them, but is there a reason you are set on that selection?
Old Jan 17, 2011 | 12:48 AM
Whoops, knew I was forgetting something..It's an M6, stock 3.42 gears
Well, I was shooting for 400 but,
I arrived at a reverse split cam because I'm not planning on getting an ls6 intake right away and I'm sticking to my stock heads. I was reading that with a good flowing exhaust with this cam, I'll make pretty good power so I thought why not. Found a decent deal on the cam so I pulled the trigger.
Old Jan 17, 2011 | 01:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Good call on the cam then. I was just checking to see if you knew about them.
Old Jan 17, 2011 | 02:11 AM
caseypryan's Avatar
I had this cam and loved it...made 392rwhp 376rw trq through 4.10's/M6/LS7 clutch kit
Old Jan 17, 2011 | 02:12 AM
caseypryan's Avatar
Oh and you should definitely look into a cut/out..mine made 10-15 hp difference
Old Jan 17, 2011 | 04:10 AM
masterz28's Avatar
This cam will be pretty good, with your setup.
Old Jan 17, 2011 | 04:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I havent seen too many custom reverse grinds, but this one is pretty tried and true. Definitely against the grain. I like it.
Old Jan 17, 2011 | 08:00 AM
Nice, thanks for the input guys. I think I'll be very satisfied with this cam.. Seeing those numbers...I can't wait to get this thrown in! And to caseypryan, I actually do have a 3" cutout immediately following the flowmaster merge, forgot to list that in the op.
Old Jan 17, 2011 | 05:02 PM
caseypryan's Avatar
Perfect! get that cam in and dynoed lets see what numbers you make! awesome daily driver cam
Old Jan 17, 2011 | 05:36 PM
01ssreda4's Avatar
The TR230 is a solid performer
Old Jan 17, 2011 | 06:04 PM
purple98haz28's Avatar
i have this cam as well...and love it. just need to get a better clutch behind it now. i love the low end torque
Old Jan 17, 2011 | 07:37 PM
TXZ28LS1's Avatar
i run a cam pretty much similar to the TR230. I have the X1 230/227 591/571 112 on a auto stock heads. I gained 70 rwhp with that cam and tuned. With bolt ons i made 322/333. With just that cam, stall, and a tune i made 395rwhp.
I love how civil my cam is. I can start it up anytime, not worrying about bucking, surging or being a pain to drive. I will be adding heads, and a ported fast intake to see how much HP i can make with this cam.
Old Jan 18, 2011 | 09:14 AM
thunderstruck507's Avatar
I have something similar but on comp xe lobes. Great low end torque, drives like their is no cam but pulls hard, especially above 3500-4k. I shift at 6300rpm. Lopes pretty damn well too so it gives that cool "big cam" sound a lot of people like without the negatives of having a donkey dick cam.
My dyno numbers looked like crap (final numbers were 350rwhp/325rwtq, but it did show 370rwhp/345tq on the same dyno in drier weather...both times were SAE corrected) converter unlocked and exhaust capped, but at the track I'm trapping like a 375-380rwhp car for my weight.
It LOVES good exhaust...I pick up an average of .15 and 2mph with my cutouts open...and I have true duals 3" to muffler and 2.25" over the axle from the mufflers. Cutouts are 8-12" behind the collectors.
The Thunder Racing lobes should be a little more aggressive in mid lift so it should make more power than mine. One of the tech gurus on here said it could be as much as a 10hp difference.
Overall I guess I'm pleased but given the choice to do over I would get something newer, slightly larger, and standard split or if I wanted to keep it reverse something like the "El Torro" cam (search). I didn't count on getting a Fast intake for the price I did so it makes a lot less sense now.
Old Jan 18, 2011 | 01:21 PM
Whew, good numbers guys! I guess they weren't fooling around when they came out with this type of cam..
Old Jan 20, 2011 | 05:46 PM
Got the cam today. It has some pitting on it.
Is this something to be worried about? I was told everything was in good shape.
Old Jan 20, 2011 | 05:50 PM
98z8uup's Avatar
You need to take a better pic. Can't make anything out.
Old Jan 20, 2011 | 05:56 PM
Yea, my camera sucks. Let me try and get a better one quick.
