Port and Polishing heads.
Wouldn't the sharper ridge create more turbulence by splitting the airflow much greater, than letting it take its own smoother path around the guide and over the swirl ridge? I personally feel like the first picture will net more mid-range power due to the swirl ramp and the smoother guide, and second more higher rpm power, but like bracketracer said "Sometimes things that you think would work don't always work well."
my personal heads did close to picture two as this is what the cnc'd head had i was copying.
Also ordered some long carbides, should be in in a couple of days. Meanwhile i will disassemble the second head and start on that.
This aluminum bit I got did what you see in the picture in like 1 minute...and suprisingly its a lot easier to control and make everything perfect.
Besides im not running formula 1 or sending it to space so what little percentage its off I couldnt care less.... they work and so do the other sets ive done.
