Kickin around this cam for a 408ci motor.
244/252 112lsa +2
drag race only car... compression high...
250 shot min... probably around 400-500 at the end of the day...
Originally Posted by T/A Medic
244/252 112lsa +2
That sounds like your getting REAL lumpy... The main factor would be make sure youve got the baddest Stg 3 bad-dude cylinder heads you can afford to support that cam.
I had a custom XE-R 238/248 done and it seems pretty wild, ill let you know how it dynos...
have to wait and see on the heads, have some ABS SPD stg3 6L being done up... i figure people are going so big on stock cubes, time to get bigger on Strokers ...
just looking for some opinions. Thanks
FWIW, our big inch N2O solid roller engines (non LS1) are at 288/302 @ .050", 700 RWHP on motor, 1100 RWHP on the spray.
does having a high compression make it easier to run a bigger cam?
well the kit i have on the car now is NOS Pro Race fogger system w/ NOSzels... i have pills up to 300 hp right now... I just need to find out if the HP Limitation on a NOSzel kit is due to the NOSzels or the plastic lines/noids...
then eventually next year sometime it will get a 2nd stage possibly
244/252 112lsa +2
should make some good power
