"etp 215" heads some advise please!!
looking at buying a used set of etp 215 heads. will i have problems getting them set up? this is a daily driver and don't want problems. there out of buisness. will i need any thing special or just longer push rods? Using small cam 590 lift range.would like to use stock rockers or maybe yella tera. will i have problems with this 11degre head?
The standard valve were REV, and there not hard to get. But not a stock LS1 length
both those rockers work, sometimes you have to shim the stands, and sometimes mill them to have the right sweep.
check the coolant and steam holes to the HG your gona use. Some were blocked on some of those casting. A lot of cars ran fine with them half lining up, but you can redrill them or slot them to match your HG and block. Its a good casting, people have gone 8.6 NA on them.
ya I don't think your gona find any shelf, and being a custom length no PN, there custom but you can get them. There is a set on here right now for dirt cheap ($120 shipped) form Christin in FL with red c5 that made 511whp with a set and streetsweeper cam years ago, Miami9???? on here. But they are more for a 4.06+ bore
Christian
Pretty much anything you want to learn about those ETP 215 cc Cylinder Heads is in the thread I started January 2007 with my 346 ci na of 511 rwhp...
Videos, pictures, graphs, compare, results in vivo, documentation, data...can be found in the link on this forum below:
https://ls1tech.com/forums/dynamomet...1rwhp-fti.html
Pretty long read I know...you will tell me if it worth it!!!
Enjoy
Christian
Enjoy
Christian
