BEST CAM FOR CNC LS6 HEADS?
AND M6. ALSO 2000 SS FREE MODS, SLP HEADERS, LS6 INTAKE, AND A4 WITH 3500 YANK. WHICH CAM WILL WORK BEST TO MAKE MAXIMUM POWER FOR EACH CAR?
THANKS.
LS1 Grand-Am Cup, 239/251 Duration @ 0.050, Racing Camshaft
Price: $439.95
Part # 88958606
Advertised Duration Int.: 294
Advertised Duration Exh.: 306
Duration @ 0.050" (I/E): 239 / 251
Lift (I/E): 0.570 / 0.570
Lobe Separation: 106
RPM Range: 4000-7000
Cam Type: Hydraulic Roller
This hydraulic roller camshaft is designed by the GM Racing Division for road racing applications in the Grand-Am series. Serious duration and lift will require that the piston to valve clearance be checked as well as major PCM modifications. For best torque, install the intake centerline 105 for best power install at 107. GM recommends lightweight valves and valve springs from the 2002-03 LS6 engine for use with this camshaft.
Note: When installing this camshaft, it is critical that you use the point of maximum lift on the intake lobe. This is not a symmetrical lobe design!
Keep in mind, and I'm not going to directly answer your question that big cams require more gear than stock, and more converter too, to really shine at the strip.
That being said, I'd like to see someone run the TR 230/224 or a grind like it with those heads and see what power they put out.
I personally would not go over 230 duration for the intake or exhaust the gains are pretty minimal. I think some of the 226 thru 228 duration works great.
<small>[ February 26, 2003, 06:34 PM: Message edited by: TXNC5 ]</small>
<small>[ February 26, 2003, 07:38 PM: Message edited by: hawkn01 ]</small>
