Budget Ls1 450hp
Due to some ill former advice I do have these parts: ls6 intake, ported stock TB, jesel J2K solid roller rockers. I'm guessing its worth my time to sell the J2k's and pick up a set of yeller ultralights or some hydraulic/cheaper setup.
These mid range cams are showing to be the sweet spot for these 4th gen F-Cars weighing in around 3500. You can HONE the LS1 to get a slight bit bigger, but not really worth it unless it needs to be done. Can't bore an LS1 or 6.
Getting over ~410rwhp will run you a couple grand. Start with either a FAST 92, full Kooks/ARH or SW LT's setup with a good merge Y and whatever catback, 25% UDP, maybe 38# injectors and then get it tuned and see how you like it. That should be around 360rw. You can add a good set of heads whenever you're ready, but those are also dependent on if/what cam you will be running, but a set of AFR205's will be great even with a stock cam. That should push the bill to around 380-400rw on a good tune. And remember, numbers don't always depict how a car feels in the SOTP or how it responds. My custom Tq cam may not make huge numbers, but it pulls like a raped ape.
If you still want more, contact PatG or PredatorZ to get a cam spec'd for what you need.
And as far as the DynoJet/Mustang dyno comments; that IS accurate, but the "lost 25hp" is somewhat inaccurate. Good tuners decide to use the Mustang Dyno because it gives an accurate load to the drive wheels to help the tuner detect any potential issues that may arise. If they use a Dynojet, those are somewhat of a free-wheel dyno. Cars and engines act differently when loaded than they do when they're free wheeling.
Oh, and get a set of gears too.
But yeah, a good bolt-on setup should get 450 crank easy.
I'd still say LS6 intake with an 80mm TB, good exhaust, and a good tune should be right around 400HP. If anything, throw some good heads on it.
