4" crank clearance
Old Feb 17, 2004 | 11:50 AM
bryan c's Avatar
Question 4" crank clearance
Does an LS1 block need to clearanced anywhere in order to use a 4" crank? Are there any other clearance issues with using a 4" crank?
Old Feb 17, 2004 | 02:14 PM
StevieZ's Avatar
No and no
Old Feb 17, 2004 | 02:57 PM
bryan c's Avatar
thanks and thanks
Old Feb 17, 2004 | 07:14 PM
Reckless's Avatar
Super Moderator
I just played around with the Eagle 4-inch crank tonight and the rods and rod bolts cleared just fine. But I did run into an issue with the crank counterweights bottoming out on the base of the Diamond pistons seen here:
I am thinking the rods are incorrect or the pistons have not been mated to an Eagle crank yet and Diamond is not aware of the clearance issues.
Old Feb 17, 2004 | 07:31 PM
99 Black Bird T/A's Avatar
H82bbad said the crank cleared fine but he had to clearance for the rod bolts. Said he used Oliver rods.
https://ls1tech.com/forums/showpost....0&postcount=29
Old Feb 17, 2004 | 09:38 PM
10secondZ's Avatar
Reckless: That suck's bigtime bro...what rod's are those and are those the diamond # 11504's? The eagle counter must be much larger..how was the reluctor clearance? Thank's,
Carter
Old Feb 17, 2004 | 10:14 PM
Mike K.'s Avatar
damn thats somthing to look out for ...
Old Feb 17, 2004 | 10:47 PM
strokedls1's Avatar
Lunati 4.075" No clearancing was done with carillo rods and je pistons
Old Feb 18, 2004 | 02:13 AM
Reckless's Avatar
Super Moderator
Those are the Eagle 6.125" rods (#CRS6125B3D). The pistons are Diamond 11519 for a 4-inch stroke and 6.125" rod on a 4.030 bore. Something is not right with the crank I fear
Old Feb 18, 2004 | 02:53 AM
Slowverado's Avatar
have you measured the rods yet Todd? probably stupid of me to ask, but just curious.
Old Feb 18, 2004 | 05:46 AM
Reckless's Avatar
Super Moderator
No I haven't. Did not think there would be any reason to measure the rods? I guess they could be incorrect? I will look into that. They might be 6.098" by mistake?
