Best LQ4 to get?
with that...what are the best LQ4s to get? I have been out of the LS scene for a while so im lost. Is an newer year like 05 the best to get? which years have the reluctor i need? any reason not to get an early year like 98-99?
Thanks in advance!
Here on the boards you will find many people who have put some major power to the wheels using just a stock LQ4 short block. It appears that w/ ARP or Katech rod bolts, the motor can handle 700+ rwhp reliably.
It would be a good idea to have a machine shop just look over your block and rotating assembly to look for any wear and tear. I purchased an '04 LQ4 shortblock that I'm still awaiting arrival of. Once I receive it, I plan on having the crank/rods/pistons checked out, new bearings installed, ARP rod bolts, and new piston rings put on and be done with it. I have confidence that I will throw whatever I want at it and not grenade
BTW: All LQ4's should be 24X reluctor.
