Pushrod Checker
Old Apr 11, 2011 | 08:09 PM
the_merv's Avatar
Default Pushrod Checker
http://www.summitracing.com/parts/CCA-7702-1/
Is this a good one..?
Just looking for some input..seems like a simple tool to use..
Old Apr 11, 2011 | 08:58 PM
bop bop's Avatar
Yep.... Works great on LS applications.
Old Apr 11, 2011 | 09:39 PM
the_merv's Avatar
Next question is how much does a Lifter pump up running vs. when you roll it over to check it..
Old Apr 12, 2011 | 05:11 AM
vettenuts's Avatar
Not sure I understand that question. The adjustable pushrod isn't installed and the motor turned over, it is used to make a measurement of length only.
Do you know how to use it?
Old Apr 12, 2011 | 05:14 AM
brian_rs/ss's Avatar
never used one either, explain? or link?
Old Apr 12, 2011 | 07:04 AM
the_merv's Avatar
You place it in under the rocker, tighten the Rocker down to spec, then adjust the Pushrod to Zero Lash. Take it out, measure the length, then add the Lifter Preload to get the proper length of Pushrod you need.
Yea I got confused with something else..
Old Apr 12, 2011 | 11:34 AM
vettenuts's Avatar
Here you go: Link
Old Apr 12, 2011 | 01:39 PM
thanks!
Old Apr 12, 2011 | 02:23 PM
bop bop's Avatar
Be sure to check both banks on the motor regardless of what the machine shop says. Some shops will tell you the heads are perfect and you only need to check the #1 cylinder. Take the extra 30 minutes to check the other side anyway.
Cheers
