Need Opinions On Stupid Big Comp Cam
In running my GTO with a MAFless SD tune and no o2 sensors hooked to the pcm.... I did a lot of street tuning on it with my wideband and Hptuners to get the exact fuel and VE maps I wanted, then locked them in and just use the MAP and air intake temp for adders to hold everything where I need it. But this is in a 408 with a 255/263 .624/.624 115 lsa
We looked in the #3 cylinder last Thursday with a Snap On scope/camera tool and couldn't see any marks in the top of that piston at that time. There was so much black soot from it running so bad that it was hard to see real clear though. Everything about this situation just didn't/doesn't make sense. That was when we started thinking that the Comp roller rockers maybe being adjusted wrong maybe why the car was running so bad. I will update this thread after I see the car again this Tuesday. Everything will be the same except the stock rockers and hardened pushrods will be on it. The customer did say that the only thing that looked wrong when they removed the Comp rockers was that you could see where the stock pushrods were rubbing on the guide plates that were installed with the Comp rockers.
From: Central Indiana Honors: 4th grade spelling bee contestant
Your customer might want to stop working on their own vehicles. I'd personally never swap a cam & rockers without doing the pushrods & valve springs too.
The customer is fully capable of changing his own parts. He just relied on crappy parts recomendations from what he thought were two knowledgeable reps from Comp Cams who both recomended this cam. My first post states he used Comp 924 springs.
Took the car to 5800 rpm on the dyno today with no apparent PTV issues. Had to stop the tuning again because of fuel pressure issues. So I guess the TRex is not the biggest cam you can run without fly cutting.
#32
So still no measurement on the ptvc...just take it on up to 7k an see if it hits
#33
450 on a Mustang dyno. We multilply this dyno's numbers by 1.14 and get pretty close to Dynojet numbers. Only did 3 pulls. One to 4400 rpm, one to 5200 rpm and one to 5800 rpm. Fuel pressure dropped bad on the last pull so we stopped until the problem can be found The fuel pump has already been changed so there may be a leak in the tank and also a boost a pump is going to be installed. It is only making around 4 psi on the boost gauge though.
Chris, the rev limiter is at 6600.
#34
We got the car back on the dyno today after fixing a fuel pump hose leak and adding a Kenne Bell BAP with pretty good results. The rest of the mods on the car are a Procharger P1SC-1, 63lb Siemens injectors, long tube headers into a ORY and a cat back. And of course, the big cam. The rear end is a 9 inch with 4.10 gears and the car is a M6. We pulled it 12 times taking it to 6600 every pull with no apparent PTV contact. Logging boost with the dyno equipment we saw a high of 7.8 #s after some belt tightening. The pull here was with the hat and filter pulled off the PC head unit. There was one pull where it went to 567 after a longer cool down but it was pretty consistant making 560 without much cool down. The power went down to 510 with the hat and filter back on. I've seen the filter restriction problem on several Procharged F-bodys.
Uploaded with ImageShack.us
