Yellow LS6 springs on a 02+Z06 cam
we test beyond limitations just to know the limits and have run them on shop cars (experimental use only) @.597 without fail. I would think you would be ok. But why not spend the $150 for some .600 lift springs for added assurance?
THIS^^ The ls6 uses lightweight valves to help control valve float being you probably arent using those valves you probably should upgrade to atleast pac 1218's. Also the ls6 valves are a little longer because the ls6 cam has a smaller base circle so if you are not using those valves it is "recommended" that you upgrade to 7.425 pushrods
