Water in Oil
Water in Oil
So I changed the oil in my trans am today, and it had some antifreeze in it. it wasnt real bad, it wasn't milky by any means, but i could see strands of coolant in it. Is this usually a head gasket?
Wait a minute ...hold on here.....
Does your radiator have a oil coiler built into the drivers side of the raiator? If so then you could just have a simple leak from your radiator to the oil cooler. In that case replace the radiator.
I dont know what they are putting in the newer F-bodies...but my Sierra has a oil coiler setup just like what i described above. Ive heard of people having this leak into the oil before because of a break in the radiator itself.
Otherwise typically coolant in the oil is caused by leaking head gasket, cracked head or cracked block. Those are the only causes i know of.
Cooler on the bottom of radiator is for trans mmmmm. Think you need to do a re-think here.
Yeah except we don't drive SIERRAs and we don't have ENGINE OIL COOLERs so your argument kinda goes out the window huh? We did have power steering coolers in the upper radiator line but not engine oil coolers of any kind. OP I would vote head gasket.
Could also be porosity or a crack in the block. Has the engine ever been overheated? You should get a pressure tester and see if you have a head gasket leaking. If you don't its time to drop a few GM leak fix pills into the rad.
Typically if there were a crack in the water passageway to the clyinder or a blown head gasket you will se your engine temp climb fast and peg out since the hot exhaust gases are going into your cooling system and the radiator simpy cannot keep up dispersing that kind of heat.
"Yeah except we don't drive SIERRAs and we don't have ENGINE OIL COOLERs so your argument kinda goes out the window huh? We did have power steering coolers in the upper radiator line but not engine oil coolers of any kind. OP I would vote head gasket."
Hence the reason i wrote "Do F-bodies have that too?".......Why don't you try using those eyes of yours ....to f'n read!
No, not down here, more Aussy and Jap cars. Only yank car i've had was a 71 Cougar.
