Injectors for Mild 5.3 Build
Old 05-19-2011, 11:10 AM
Bilster's Avatar
Default Injectors for Mild 5.3 Build
Doing a mild 5.3 build with 10.5:1 compression, Elliot Lloyd ported 5.3 heads and a Comp Cams 200/212 .527/.510 117 cam. This is a truck motor that's going to see some mild towing. I'm wondering if the stock 5.3 injectors are upto the task. I have access to a set of 28.8 LS1 injectors. Will these fit the stock 5.3 intake or do I have to have a set of LS1 rails? What is the stock 5.3 injector size? I would like to send the ECM in for a tune and need to work out the injector size before then.
Old 05-19-2011, 12:32 PM
NemeSS's Avatar
Prolly can reuse the 5.3 injectors. Or can use the truck version 42lb. From 8.1 trucks. I think the stock lq4 injectors can be used also. Idk if there any different from the 5.3s though
I have few sets of lq4/9 injectors if interested
Old 05-19-2011, 02:48 PM
parks450's Avatar
Id do a set of ls2 injectors from a gto or something which are 36lb.
Old 05-19-2011, 06:28 PM
Bilster's Avatar
Can I put them in using the Vortec injector rails?
Old 05-19-2011, 09:14 PM
LilJayV10's Avatar
28.8 should be more than enough. They are good to around 450rwhp. I have 430rwhp and I am about 85% duty cycle.
Old 05-19-2011, 11:40 PM
Bilster's Avatar
I figured the 28.8s would be a good choice but I need to know if they can be installed on the truck intake without mods to the rail.
Old 05-19-2011, 11:50 PM
LilJayV10's Avatar
As long as the truck rail you have uses the taller EV1 injectors they should work fine.
Old 05-20-2011, 04:29 PM
Bilster's Avatar
Thanks!
Quick Reply: Injectors for Mild 5.3 Build
