Want a Lopey Cam
I want do a cam real soon for the summer, but i want it to be streetable, but i want an agressive lope to it, im running a m6 wit 342s, but i will upgrade soon to a 390 rear and a ls7 clutch, wuts a nice one to go with?
I have the same cam as KevinR and it has a nice lope to it. If you wants something with extream lope get a cam ground on a 109 or 110 LSA. Just dont get to much lift or advance ground in the cam so you dont have PTV clearence problems. Plenty of companies offer custom cams and that should be perfect for you.
I am uploading a video with exhaust hooked up asap, but this is my 228r on a 112 with open headers video-2011-05-02-19-04-45.mp4
Thanks for the replys guys, yea Kevinr that seems like a huge lift cam there, and would love to hear it, did u have any clearance issues? does ur car have stock heads?
Yes, stock 241's and no clearance issues at all. I think the closest it got was .080 on the intake if I remember correctly. I wouldn't really consider it a "huge lift" cam compared to the trak cam, MS4, and plenty of others. It is a bit bigger on the duration side, but it's basically a step down from the trex, which I did try first.
ok cool then anything in that area should be fine
yea i plan to upgrade the springs to the best ones i can get
