Forged 346 pistons/rods??
Old May 23, 2011 | 07:29 PM
kidcamaro98's Avatar
Default Forged 346 pistons/rods??
I am looking to build my car to handle a good shot of nitrous. However, I am having trouble finding stock bore forged pistons? Right now I just have a ms3 cammed ls1 (mods in signature) and I put a 150 shot through it. I just want to build it for nitrous so I dont have a gut wrenching feeling at the back of my throat everytime I spray.
anyone know who sells them? Like I said, I just want forged rods and pistons for nitrous, and arp rod bolts. I would like to get around 650-700rwhp after all said and done on a 250 shot. I already have a ported ls6 pump and the fuel setup to get me there as long as a moser 12 bolt.
Old May 23, 2011 | 07:54 PM
zacht's Avatar
im looking into doing the same thing as well. i dont think they make them stock bore, but like a .005 over.
guess in my build im going with some diamond pistons -2cc valve reliefs, rings gapped for nitrous 2-300 shot, steel napier ring, and callies compstar rods.
most vendors can hook you up. also ask if you can use your block and crank to save some money.
i think im settled on a newer vendor we have, ah...cant remember the name, they're in topeka kansas. using my block and crank with that stuff in it was i think 26-2800...
Old May 23, 2011 | 08:05 PM
KILLER-LS1's Avatar
whenever you change the pistons and rings, you have to hone the block so that the new rings can ceat probperly. when they rehone the block, you just tell them what size bore you need according to the piston that you order. honing is not that expensive (most shops will hone up to .010" over). its when yopu staret boring the block that it gets more expensive. also, the bores are not perfectly round from the factory, so you will benefit by getting a good oversize hone at a reputable machine shop.
Old May 23, 2011 | 08:44 PM
there is a pretty good machine shop literally within walking distance from my apartment. Maybe I will swing in there soon and just see what I come up with, for numbers and what not.
Old May 24, 2011 | 09:49 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got forged Probe pistons and Scat Rods in my 346. Picked them up off here a few years ago for $650
Old May 24, 2011 | 08:50 PM
from where?
what are the power ratings on them?
Old May 25, 2011 | 09:04 AM
roswald0511's Avatar
How are the probe pistons holding up?
Old May 25, 2011 | 09:08 AM
lemons12's Avatar
If I'm wanting to spray 200-250 hit and not worry about it.. what Is the cheapest one could get out for? Rods piston etc.. I'll reuse my stock crank.
Old May 25, 2011 | 01:23 PM
Z28/2002's Avatar
Originally Posted by kidcamaro98
from where?
Got the from the classifieds section, couldn't tell ya what they are rated for I've never looked it up
I've hit them with 2 bottles worth of a 125 shot and they are doing great. Just had the motor rebuilt and they cleaned up and checked out like new. This fall they will be hit with a 175 shot
Old May 25, 2011 | 07:59 PM
well that doesnt tell me anything lol
I have been spraying a 150 on my cam only ls1.
