Ultimate Ca Setup
Old Feb 24, 2004 | 09:46 PM
52172's Avatar
Question Ultimate Ca Setup
I live in Ca which obviously sucks, but we have to do what we have to do so my main objective is to build the highest output MF motor that will pass the sniffer her in Ca. Before I have my bottom end rebuilt I am going to try to max out the bottom end here in Ca!!!! I plan on buying some as cast 205cc afr heads and have them hand ported to the max along with a custom grind cam that will maximize power and minimize emissions and hope for 470 rwhp. I have all the bolt ons plus a intricitley ported Holley intake man that should maximize the setup. The cam specs are somewhat close to 228/228/.590.590/114. What are the opinions? Real life experiences? The heads will be port matched to the intake and after I think about it there are no real life experiences so how about opinions!!!
Old Feb 25, 2004 | 12:56 AM
greekss's Avatar
228/228/.590.590/114 ............... I doubt this will pass
Old Feb 25, 2004 | 05:46 AM
jrp's Avatar
jrp
SN95 Director
agreed. im gonna hit up FMS and see if they can hit me up with a custom cali grind
Old Feb 25, 2004 | 11:05 AM
Gary Z's Avatar
Forced Induction
Old Feb 25, 2004 | 11:16 AM
CHRISPY's Avatar
Go with big cubes, great heads/intake and a cam with wide LSA. Should be able to build a 470-500RWHP motor that will pass easily. Good tuning and it would be a piece of cake
Cheers,
Chris
Old Feb 25, 2004 | 11:29 AM
Spellbound's Avatar
I think it would be pretty hard to make 470 NA with stock exhaust manifolds or smog legal shorties unless you went FI. A guy in our car club is making 462 with just a hooker cat back and 8lbs of boost.
Old Feb 25, 2004 | 11:42 AM
CHRISPY's Avatar
A 422 with proper heads/cam combo will make 470 no problem or very close to it IMO Also you will be running regular headers/Ypipe outside of emissions testing time right?
Old Feb 26, 2004 | 12:10 PM
52172's Avatar
I would like to stay with the JBA shorties, mufflex test pipes, magnaflow catback,qtec cutout, if I can. Will my exhaust set up
hurt my performance that much? I was actually going to go with a true dual system hooked up to the mufflex test pipes which would pass the smog test.
Old Feb 26, 2004 | 12:46 PM
Steve1969LS1's Avatar
Do you want it to pass visual also?? because that matters ALOT..
Best sniffer AND visual system would be:
JPB shorty headers
220 thunder cam
K&N FIPK induction
High flow exhaust (Corsa, GMMG, etc)
And they all have CARB numbers..
If you just need to pass sniff (becuase you know someone that will look the other way on the visual) then you can do quite a bit more..
Old Feb 26, 2004 | 02:28 PM
JZ'sTA's Avatar
I agree with the F/I
Think about what he is trying to accomplish.
470 RWHP with junk exhaust and a small cam.
NO WAY IN HELL, might not even get there with hugh cubic inches.
You need every piece of the puzzle to get to 470 and most doing it have cams that are 232+ duration. Pimp *** heads, and LT headers.
Dollar for dollar you would be way cheeper going F/I.
Most long block stroker motors are 10,000+ easy, and to go resleaved and stroked your 12000+ dollars. Keep your shortblock, buy a set of 6.0L 2500 dollar heads from Jay @ Absolute speed, or TEA, and then buy a nice S/C setup or Turbo.
Lets take a top of the line and go with a real nice kit from 1/4 mile performance.
6500 dollars and it includes everything you will need to install it and have it running.
So you have 6500 dollars plus 2500 for heads and 150 for a cam plus labor and your done. Run 9psi and put down 470+ all day long. Should go fine for emissions as well.
Just my oponion.
Old Feb 26, 2004 | 03:16 PM
52172's Avatar
superior automotive in anaheim is getting 560+ fwhp and passing emissions with their 383 this would equate to 470 rwhp.
Old Feb 26, 2004 | 03:17 PM
Terry Burger's Avatar
The largest cam that will pass is maybe 224 duration/114ls, and only if you have good stock cats. Forget about headers as those are illegal too. Basically if you want a smog legal setup in CA expect around 380rwhp with the stock bottom end, or 440rwhp if you spend a ton of money on 400+ci bottom end.
Of course, you can always do what you want and put it back to stock every two years.
Old Feb 26, 2004 | 03:19 PM
JZ'sTA's Avatar
Nice to see that someone is doing it with a 383.
However that is only 1 example, and I am sure there are 100's of F/I guys making that power.
I dont have a SC or Turbo, and dont plan on ever buying one, so I am defentially not making this suggestion because of my setup, only because this is what seems to work great for what is trying to be accomplished.
Old Feb 26, 2004 | 03:21 PM
jrp's Avatar
jrp
SN95 Director
supposedly there are cars getting 400rwhp+ hp through stock cats and manifolds at don lee's auto
Old Feb 26, 2004 | 04:00 PM
52172's Avatar
I am not sure of the custom cam superior auto is using but I know it passes smog (barely) I know it has longer duration than 224 I believe it is a 228/228. They must tweak the tuning to pass smog with that cam but they are doing it which is what counts.
Old Feb 26, 2004 | 04:16 PM
greekss's Avatar
imma have to look into FI too..... but even then is that hp # achievable ?
Old Feb 26, 2004 | 05:02 PM
Trojan T/A's Avatar
There used to be a guy putting down around 540rwhp through JBAs and a Vortech kit in San Diego. His name was Blown Interceptor. He doesnt have the setup anymore, but it's proof that it can be done. It takes a lot of tweaking though with FI to get everything to work right when you are pushing the blower hard.
Old Feb 26, 2004 | 05:12 PM
Since when are F/I units smog legal?? Did they get CARB numbers when I wasnt looking???
Old Feb 26, 2004 | 05:16 PM
Well I'm sure its possible if you have all the bolt ons, but on average this guy should expect 380rwhp if he goes that route. If he does the LS6 intake, ported TB, UD pulley, good dyno tune, cutout, etc then he might hit a peaky 400rwhp.
RE FI, I think the Vortech kit is smog legal, and I know the ATI kit is legal on Corvettes (not sure about their FBody kit). I'd just do a mild heads/cam setup with long tubes, and swap back to stock manifolds for smog time. You might be ready to sell the car in 2 years anyway so why sweat it. As long as you have long tubes and high flow/no cats I'm sure you can hit 420rw with a 224ish cam.
Old Feb 26, 2004 | 05:20 PM
jrp's Avatar
jrp
SN95 Director
through stock manifolds and cats? i dont see that happening, especially with a smog grind (224>) even with some nice heads.
