BEST AFTERMARKET OIL PUMP ???
LS1Tech Administrator
Received 1,722 Likes
Re: BEST AFTERMARKET OIL PUMP ???
I have an ARE pump. I'm very happy with the results. I get about 10 more psi from idle on up.
Stock pump idle: 35psi
ARE pump idle: 45psi
Stock pump WOT: 60-65
ARE pump WOT: about 75-80psi
<img src="http://www.slpnj.com/img/part_img/55001.jpg" alt=" - " />
http://www.slpnj.com/view_product.as...&SHOWEMAIL=Off
SLP Oil Pump -
SLP Oil Pump -
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bdawg/98mecham9:
<strong> I need a new oil pump real soon. The stock o/p idles @ 16 to 20, and goes to 40 @wot. Suggestions, for a new one...????? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a Katech oil pump, and I'm getting the same oil pressure as you are. I've heard that Katech doesn't shim the oil pump for more pressure unless you ask them to (I didn't know that when I ordered it, though).
I did a hard stop from about 110mph earlier today, and the low oil pressure warning came up at the end. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I don't think it's a problem with the oil pump O-ring, since I replaced the o-ring once already when the oil pressure was *really* low after a cam swap.
How could I find out if it's a faulty pressure sending unit or worn main bearings?
Thanks,
Miles
Thanks,
Miles
I'm currently having oiling issues as well. My new engine has less than an hour run time on it and all of a sudden after I start it up, the check gauges light comes on. I've talked with several forum directors and they seem to think that the pump failed.(brand new pump) So looks like a new one for me.
Good luck and a ttt.
Q
Q
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Q:
<strong> (brand new pump) So looks like a new one for me.
Q </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What brand of pump were you using?
Are LS6 and LS1 pumps interchangeable?
<strong> I need a new oil pump real soon. The stock o/p idles @ 16 to 20, and goes to 40 @wot. Suggestions, for a new one...????? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Okay, was it always like that or just recently? Did it decline steadily or just drop all of a sudden?
To me, an oil pump is an oil pump. They all start from the same source (GM), so it's just minor differences. I just put in a stock oil pump because I've had two aftermarket oil pumps get stuck on me (0 oil pressure). In both cases it was just small shreds of metal that got lodged and prevented the valve from closing. So after that, I figured what was the point in getting an aftermarket pump since it's not like a new design that gets around that problem.
<small>[ February 28, 2003, 06:15 PM: Message edited by: akw408 ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Miles in Michigan:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bdawg/98mecham9:
Thanks,
Miles </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can try replacing the sending unit or sticking a mechanical gauge on there. Or tearing down the engine to look at the bearings (I highly doubt you want to do that).
All I can say is that ALWAYS replace the oring when putting in a new pump. Trust me. I wouldn't be surprised if you took your pump off right now and found that the oring was missing. It happened to me once, even though my friend and I both know we put the oring on there.
Thanks,
I dont know how to highlight a sentence & then respond to it.But I have had the motor for 4000 miles. It has a brand new gm pump. I have a friend with an A.R.E. ported pump that idles 45+ and goes 80+ at wot. Thats what i want. When the builder built the stroker i didnt know what i know now. So i gotta pull the cam, & while im at it i might as well put in a good oil pump. FYI i gotta have the only stroker that has only 340 rwhp ( he picked the cam 205/212 .540 ). I think im going to the mti R1, and i really like what ive heard about A.R.E. oil pumps. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
<strong> I dont know how to highlight a sentence & then respond to it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just click the quote marks on the first line of someone's post, it'll put the right text in to do a reply with quote.
<strong>But I have had the motor for 4000 miles. It has a brand new gm pump. I have a friend with an A.R.E. ported pump that idles 45+ and goes 80+ at wot. Thats what i want. When the builder built the stroker i didnt know what i know now. So i gotta pull the cam, & while im at it i might as well put in a good oil pump. FYI i gotta have the only stroker that has only 340 rwhp ( he picked the cam 205/212 .540 ). I think im going to the mti R1, and i really like what ive heard about A.R.E. oil pumps. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think you can shim your oil pump to have it make more oil pressure, with just a washer. Supposedly that is what companies do that sell oil pumps, to make them put our higher pressure. I don't know how to do it, but I've seen people talk about it here.
Zeta,
The pump I had before I bought from a guy on this board. I actually took the pump out today and found that it looked the same as a stock oil pump inside and out with the exception of an indentation on the rear of one of the pumps. Inside, the "ported oil pump" was some small pieces of trash holding the valve open. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> I think it was suppose to be ported (at least that was what I was told). <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I am now running a NEW GM LS1 oil pump and I have 40psi of pressure at idle. I haven't got a chance to WOT it yet. My NEW GM pump looked a lot better than the supposedly ported unit that I bought. It was even polished. The "ported one" had small stress fractures inside and out where as the GM unit was flawless. So, all in all I saved aprox. $70 by buying a stock one from the dealership over a ported unit. From now on if it needs to be ported I'll do it myself. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I have an ARE pump. I'm very happy with the results. I get about 10 more psi from idle on up.
ARE pump WOT: about 75-80psi </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What he said. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The Katech pumps are known to be very reliable, however, they maintain a stock to slightly above stock [HOT] oil pressure of:
40 PSI @ Idle
55 PSI @ Cruise and Above
Ron,
<small>[ March 02, 2003, 09:52 AM: Message edited by: Kimchee and Rice ]</small>
40 PSI @ Idle
Ron,
<strong> Q,
what brand/where was your old pump from? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll email you when I get home.
<strong> Q,
I just installed a TR oil pump today on my rebuild. It has around 60psi @ cold start, 43psi @ idle, 55psi @ cruise, and ??psi @ WOT ( only has 25 miles on the new short block). So far I like my TR pump for $129.
John
John
