Startng my Cam install!!
Here is everything that ill have for the install. Let me know if I'm good to go. Also i have a few questions...
Parts..
-Torquer V3 Cam (231/234 .648"/.598" 111LSA As printed on cam card)
-PRC Dual valve Springs
-7.425 Hardened push-rods
-Titanium Retainers/Spring Seats and new valve stem seals
-LS6 Ported Oil Pump
-LS2 Timing Chain
-GM Basic Cam install gasket kit
-ARP Crank Bolt
-BBK SSI Intake Manifold (reusing stock coolant lines and o-rings)
-Red loctite
-Blue loctite
-6 Quarts of oil + Filter
-Assembly Lube
-New radiator Hoses
-New Belts
-New idler pullies (not necessary, but mine are squeeking like mad)
-Wooden 5/16" dowels to hold lifters up
-1 Gallon of Dex-Cool
Am i missing anything?
Questions
1.As long as the timing mark on the crank gear is pointing straight up your good to go? i dont need to turn the motor over to get a certain cylinder TDC or anything like that before trying to put the cam gear on correct? Then just position the cam so the alignment dowel looks like itll go right on the gear while the timing mark is facing straight down right?
2. Any tricks on how to not drop the oil pick up tube bolt?
3. would it be a good idea to install my intake, then start the car up to make sure everything is sealed, considering im doing the cam the next day?
4. the previous owner had the coolant system flushed, but it looks as if he used regular antifreeze and not dex cool. Should i stay with that antifreeze or go back to dex cool?
5.last question! Are the valve spring compressors from the parts store reliable? Ive heard of them breaking bolts off in the head, and i dont have time to order a nice one, nor do i want to....Anyone used them before?
Thanks! ill post a video of it when i get it done,.....and of course pictures!
Put your crank dot strait up, cam dot strait down (the cam sensor will tell the engine which cylinder to fire)
Get some fishing line and when you loosen the pickup tube bolt loop and tie the string around the bolt, then finish unscrewing it....pull the bolt out with the line.
Might want to have a pen magenta handy just in case
Good luck!
Oh and by the way, did you get the cam package from Texas Speed?
NVM: I re read your post and saw your dowels listed, good choice, I think thats the best way to do it.
I have that same cam and my paper work says a .643 lift. I've seen both numbers flying around. Maybe someone from TSP can confirm. If funds allow might as well do a smaller crank pulley for another 10hp.
Not at this time
Do i really need to intake gaskets, i was told by the ws6 store to reuse my old ones...
