Patriot Performance Heads LS6/LQ9 (pics)
#43
Originally Posted by Dave00C5
Well it goes to show that even Absolute ships out a bad set of heads at times. Don't fret as my high dollar gtp's didn't cut the mustard either.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#44
#45
There is also a signifigant difference between a set of heads that, for whatever reason, doesn't flow as much as they should, and multiple sets of heads that have oil consumption, valve spring, retainer, and valve seat issues which have resulted in at least two catastrophic engine failures. *allegedly*
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#46
This is the exact reason why you cant go by flow numbers, the first 5 sets of heads I did when i first started I had a flow data bench that reads about 25 cfm higher than my new superflow bench, It was a real shock to me when I got my new bench december of 02. My flow numbers now can be backed up by thunder racing I have sold a few sets that went through them and Angie and Paul were shocked when the heads flowed within 2 cfm of what I have stated. feel free to give them a call. There is a learning curve and progression when porting and learning these heads and Im sure Patriot is learning and progressing as they move on. I know I still am, I have more than 1 car that hit 500 rwhp and now my goal is to hit 525rwhp
Bob good luck with your car and set up I wish you were running my heads but I am always here as a friend if you need anything
Jay{absolute}
Jay{absolute}
#47
Originally Posted by mike m
Ok those heads were sold to mr b. 11/02 . and at that time those were good dyno #'s. Mr B why dont you flow the new set of heads you have and compare a new set of PP heads to a new set of AS heads. seems more fair to me.
#48
Jay{absolute}
Jay{absolute}
Chef has your heads.. and he has a M6 with 3.73's.. we will post the dyno numbers. Thanks for going out of your way to deliver the replacements.
I agree about the learning curve.. both AS & PP have encountered this.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#50
For what it is worth, ALL THESE head porters, will have problems from time to time. I ported my own heads, so in no way am I a fan of any one companies heads. My heads ended up flowing about what AS Stage 1's flow with stock valves still in my heads. I did alot of research before I ported my heads and let me tell you guys this, these heads are no piece of cake to get to flow. I have seen some really good numbers (rwhp and rwtq) come from AS, TEA, MTI, and PP. All this bashing of AS and PP needs to stop, these guys are giving you great products at REALLY good prices, Keep up the good work Terry and Jay.
#51
