Injector recommendation
Old Jun 12, 2011 | 07:07 PM
Double Aught's Avatar
Default Injector recommendation
I just dropped off the 'Hawk at my builders' place and want to know what is the best choice for an injector? I am using the AI CNC'd 241 and they recommended this grind for my application- 230/234 .630/.630 all on top of a stock cubed 346. My builder says to use a 42lb injector, but after much research, lots of guys here and on the Corvetteforum use the SVO 30lb. I am leaning towards the SVO units. Thoughts?
Old Jun 12, 2011 | 10:17 PM
01ssreda4's Avatar
I'd run an FIC rejetted/flowmatched stocker over an SVO. I've owned both.
Old Jun 12, 2011 | 11:24 PM
BrntWS6's Avatar
^^^ That's what I use, I'd think you'd need at least a 36lb.
Old Jun 13, 2011 | 12:20 AM
BennyB's Avatar
FIC or 42lb SVO injector cant go wrong with either
Old Jun 13, 2011 | 11:32 AM
What or who is FIC? I would like to go with a flow-matched set also.
Old Jun 13, 2011 | 02:56 PM
BrntWS6's Avatar
http://fuelinjectorconnection.com/shop/
Old Jun 13, 2011 | 02:57 PM
BennyB's Avatar
fuel injector connection
Old Jun 13, 2011 | 03:14 PM
99Bluz28's Avatar
IMO, go with the 42's to give you some room to grow.
Old Jun 13, 2011 | 03:46 PM
PREDATOR-Z's Avatar
bingo
Old Jun 13, 2011 | 07:27 PM
Pipelayaz's Avatar
This.
Flow matched preferably.
Old Jun 13, 2011 | 07:40 PM
I checked out there site and found some bosch blue demon injectors that they work up to your specs. All are flow matched. Now, will I need to put on an adjustable fuel pressure regulator or will the factory fuel pressure be sufficient?
Old Jun 13, 2011 | 09:43 PM
01ssreda4's Avatar
I had FIC injector spec me some stock 42lbers (at our pressure). Remember SVOs flow at 43 psi. So a 30 will be a 36 in our car (59 psi or so), and so on. I had them do straight up 42s for my application.
Old Jun 13, 2011 | 09:55 PM
Steve01SS's Avatar
I ran 42 green top SVO's for over 2 years with H/C. No problems here.
Old Jun 13, 2011 | 10:08 PM
Cool, so I guess I can tell them stock LS1 fuel pressure. I really don't want to buy the AFPR if I can avoid it, as I do have a budget that right now is getting near the end.
