347 rotating assembly help
Old Jul 2, 2011 | 01:15 PM
kons02Z28's Avatar
Exclamation 347 rotating assembly help
I am building my motor for about 25lbs of boost, im wanting to go with a callies stock stroke crank 2" journal, callies i-beam rods, diamond custom pistons and hell fire rings, the bore will be 3.905, some sponser deals and help would be appreciated
Old Jul 2, 2011 | 01:19 PM
98SSClone's Avatar
For 25lbs of boost, you might want to consider H-beam rods over the I-beams.
Old Jul 2, 2011 | 01:34 PM
kons02Z28's Avatar
if im not mistaken the I-beam rods are right for my setup considering for lots of boost ,you want as lightweight as possible roating mass thats the reason for the smaller journal crank from what i understand ,sponsers can chime in at anytime
Old Jul 3, 2011 | 08:44 AM
Steve01SS's Avatar
For 25psi, you'll definitely want some nice rods. Not $300-400 Eagle's/Scat. Thats a LOT of boost. Seems like you have a nice crank picked out. I would go with a 6 bolt style head/block at that level.. $$$
I would check with HKE, VA Speed or some of the other places here that build high end motors after the Holiday weekend.
Old Jul 3, 2011 | 10:18 AM
mark21742's Avatar
I went with Eagle H beam rods.....they don't weigh that much more for the added strength they give you and defineatly worth the extra money.
Old Jul 3, 2011 | 02:07 PM
kons02Z28's Avatar
steve01ss thanks man yea i am definitely trying to do it right, I got the block o-ringed and the heads reciever grooved and going with arp head studs, i think it will be good with 4 bolts, i guess time will tell, mark im hoping some sponsers will chime in on the rod situation and kinda give me the ins and outs on the H-beam and I-beam for my setup,im in the market for these parts, and thanks guys for all the help keep it coming
Old Jul 3, 2011 | 05:00 PM
KCS's Avatar
KCS
Moderator
Since you're planning on cramming 25psi down its throat, you probably shouldn't worry so much about the weight and focus more on the strength.
Old Jul 4, 2011 | 01:23 PM
JPH's Avatar
JPH
I would be concerned with using maybe a 6 bolt head/block setup with that much psi.
Old Jul 4, 2011 | 02:52 PM
King Nothing's Avatar
i hope you got a 5.3 iron block for this and not an aluminum block
Old Jul 4, 2011 | 02:57 PM
Fb0dy0nly's Avatar
why do u say that? A properly setup aluminum block with a strong/quality rotating assembly along with a tuner who knows what hes doing can hold the power no problem.
Old Jul 4, 2011 | 03:23 PM
KCS's Avatar
KCS
Moderator
Maybe with MID sleeves, but not on the stock gray iron sleeves.
Old Jul 4, 2011 | 03:51 PM
oh no doubt at all. i'm not sayin it won't work, i'm sayin the aluminum block won't last as long as iron, iron is stronger than aluminum . . . not many people want to rebuild the same thing twice because of a poor choice
Old Jul 4, 2011 | 07:41 PM
S10xGN's Avatar
A lot of good points being made, hope you'll consider them. 25# is a LOT of boost... With that much boost, you won't be turning too many RPM's. As KCS said, build for strength! Forget the 2" journals, bigger is better in your case. If you're determined to stay with 4 bolt heads, at least upgrade to 1/2" studs. I run 23# on my GN powered S-10 on a that motor was designed for boost and it's not something you do lightly. On an engine designed for zero boost, you'll really need to do your homework.
Old Jul 20, 2011 | 03:38 PM
kons02Z28's Avatar
it is the stock aluminum block ,4 bolt heads,thought about the 1/2 studs but have not decided yet
Old Jul 21, 2011 | 12:31 PM
matrixiskool's Avatar
May as well not build that motor if youre not going with 6 bolts or 1/2 studs. Youre going to need your heads really clamped down.
Old Jul 21, 2011 | 03:45 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
http://www.texas-speed.com/p-762-tsp...-assembly.aspx
Check us out for that rotating assembly! We can get you setup with the Callies crank, Callies H-beams (or I-beams for a little more $$), Wiseco pistons, bearings and balanced all for about $2600!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 22, 2011 | 04:33 PM
kons02Z28's Avatar
thanks for stepping up to the plate matt im willing to spend the little extra money now to make it right with the i-beams.Why is everyone saying h-beams are bettter is what i cant figure out,the true i-beams are rated for 600 more horespower whats up on the custom diamond pistons?
Old Jul 22, 2011 | 04:43 PM
I'd go custom Wiseco before a custom Diamond if you're just wanting extra coatings and such on your pistons. We've had more success on the boost combos with the Wiseco pistons than we have with Diamonds.
__________________
Old Jul 23, 2011 | 02:59 PM
Tommyv8's Avatar
H-beams are stronger, yes?
http://www.texas-speed.com/c-121-connecting-rods.aspx
