Spring Removal Tool
Old Jul 8, 2011 | 01:28 PM
3rdCoastPowerSports's Avatar
Default Spring Removal Tool
I currently have my 241 heads off of my C5 corvette,,,, im installing a TSP233/239 cam so i am upgrading my valve springs and was wondering which Valve spring tool i should buy? Im kinda on a budget and like i said i currently have the heads off so i would like to load the heads before sticking them back on the block.
Thanks ya'll
Old Jul 8, 2011 | 01:58 PM
mike171562's Avatar
I rented the Spring Tool at Autozone, it was 26 bucks and you get it back when you return it.
Looks like this
Its slow, but its cheap and it works.
Old Jul 8, 2011 | 02:53 PM
vettenuts's Avatar
Looks like this
Do not, under any circumstances, use this tool on aftermarket valve springs. It will scratch the springs and lead to premature failure. Only use the type that presses on the valve spring retainer, which with the heads off, can also be rented from Autozone.
Old Jul 8, 2011 | 04:39 PM
01ssreda4's Avatar
I have always used a Tim's tool. Works great.
Old Jul 8, 2011 | 11:35 PM
i guess im headed to autozone to check out what they have... thanks for the advice guys
Old Jul 9, 2011 | 12:51 AM
garygnu's Avatar
TSP sells a nice spring compressor tool.
Old Jul 9, 2011 | 01:33 AM
z99ls1's Avatar
Restricted User
I used that tool on many different valve spring installs and have been completely fine.
Old Jul 9, 2011 | 01:35 AM
z99ls1's Avatar
Restricted User
Could you post a link I can't find it
Old Jul 9, 2011 | 01:50 AM
1sicss's Avatar
I recently changed my cam and I as well used TIM'S TOOL very reliable and a good price. Look for it under the search he can also sell you the tools and spark plug fitting to keep the valves up if the heads are still on the car all for about $60.00-$70.00 bucks not a bad price for both.
Old Jul 9, 2011 | 08:42 AM
SOMbitch's Avatar
I am borrowing a Comp Cams tool right now and it is SUPER nice. Does both an intake and exhaust at once so saves some time too...
Edit: >>>>> http://www.compcams.com/catalog/CPG_...G2011NP_10.pdf
Old Jul 9, 2011 | 11:04 AM
Camaro Z's Avatar
I would go with any of the valve spring tools that do two springs at once.
Old Jul 9, 2011 | 11:41 AM
ZeeOSix's Avatar
Haven't seen that one before ... that's a nice design because you can remove the springs from just one cylinder if you had to without disturbing any of the other rocker arms on the head. It sits down on the rocker trunion stand.
Old Jul 9, 2011 | 12:49 PM
z99ls1's Avatar
Restricted User
What is the price on the comp cams tool?
Old Jul 9, 2011 | 12:53 PM
z99ls1's Avatar
Restricted User
Wait the comp cams and the one from tsp are identical im pretty sure.
