LS2 vs LS1 Lifter Trays
Which ones are preferred and why? I hear if you go the LS2 route you have to drill holes for oil to pass through? Sounds like a hassle; why not jus' go with the proven LS1 lifter for half the price? ($16 vs $32)
The addition of oil drain holes is practiced on both designs for the same reason, to get oil off the top of the lifters.
I went with link-bar lifters so no trays here.
I don't like the idea of drilling the holes. It weakens the lifter tray.
The theory is that drilling holes in the lifter trays will allow oil to return to the low end of the engine more quickly. The counter theory is that since the oil trays hold a finite amount of oil, once they become full the rate of oil returning to the low end of the engine will actually be unaffected by the holes in the lifter trays.
I personally have no opinion as to which theory is correct. I have link-bar lifters with no trays.
https://ls1tech.com/forums/generatio...-number-2.html
And drilling in this thread:
https://ls1tech.com/forums/generatio...ter-trays.html
