identify this block please.
Old Aug 7, 2011 | 08:23 PM
bp944's Avatar
Default identify this block please.
I'm looking at a block that's been in storage for a long time and need a lot of work. Owner doesn't know much about it other than he claims it to be an LS block. He has given me this information on the casting numbers. None seem to match any casting numbers I can find.
"GM 6.0L
Here are the other numbers on it: X267735. It has a 124 with 4 right under that and 8039213120 on it too. I believe the other number says 83092 but its hard to make out"
Old Aug 7, 2011 | 10:22 PM
itsslow98's Avatar
Is it aluminum or iron? and it will say 4.8, 5.3 5.7 or 6.0 on the back of the block.
Old Aug 8, 2011 | 11:56 AM
bp944's Avatar
its 6.0L. But he's not sure if its aluminum or iron.
Old Aug 8, 2011 | 12:03 PM
Z/YA's Avatar
Well for staters he could try picking it up, pretty much a dead give away between a steel and AL block
Old Aug 8, 2011 | 12:37 PM
Rise of the Phoenix's Avatar
That is true.
Old Aug 8, 2011 | 12:41 PM
King Nothing's Avatar
Yep lol aluminum can be lifted a bit easier since it's about 100lbs less
Old Aug 8, 2011 | 01:26 PM
parks450's Avatar
Take the first number to the dealer they can run it.
Old Aug 8, 2011 | 01:27 PM
parks450's Avatar
Take the first number to the dealer they can run it. And its usually pretty obvious if its cast or aluminum.
Old Aug 8, 2011 | 02:10 PM
aAZz's Avatar
Yea wen I went from iron to aluminum there is a huge difference in weight. I put little effort 2 pick up a aluminum block and let's just say we need 2 people for iron
Old Aug 8, 2011 | 02:33 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Put a magnet to it and you'll know if it's iron or aluminum (can it really be so dirty that he can't tell by looking at it?)
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 8, 2011 | 06:06 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Although none of your numbers are in this short list, it'll tell you where to find the casting and/or part numbers on the LS engine block:
http://www.southernperformancesystem...k-casting.html
Old Aug 8, 2011 | 09:55 PM
redss86's Avatar
There should be an 8 digit number engraved on one side. It will be on a machined surface, so if the block is dirty you may need some brake cleaner to clean it off. If you can get it, I can look up the VIN and tell you exactly what you have. "X267735" looks like a part of a VIN, but its only 7 digits and I have to have 8 to look it up.
