Corvette oil pan on F-body
Old 03-05-2004, 07:36 PM
2001CamaroGuy's Avatar
Default Corvette oil pan on F-body
What would have to be modified to make it fit? Once modified, would there be any gain? I am under the impression that the Corvette oil pan is "shorter" (more ground clearance) than the f-body.
Old 03-05-2004, 07:47 PM
ROGERSPERF.'s Avatar
You need to do what ever you can to get the oil sump away from the spining crank.so putting a shorter oil pan on would be no good unless you can blow out the sides of the pan and make it fatter.
Old 03-06-2004, 09:22 AM
so......? info/help?
Old 03-06-2004, 07:44 PM
BB
BB's Avatar
I think what is being said is you have to keep the oil away from the crank. That being said I would think a vette pan would work. But I doubt it will with the stock k-member. Maybe it would fit with an after market one. I would think it will bolt right up since the blocks are the same.
So, I guess the real question should be what benefit is there of going to a different oil pan. As for ground clearance you won't get any with that stock k-member.
Old 03-07-2004, 12:58 PM
I have a BMR K-member on my car.
Old 03-07-2004, 02:20 PM
AZ Power & Sound's Avatar
the Z06 oil pan holds pressure better in corners and hard acceleration... wasnt a prayer of making it fit on my car though so I put my stock oil pan on with my LS6... might work with your BMR though?
Old 03-07-2004, 03:16 PM
BB
BB's Avatar
OK, now I am curious if it will fit with a after market k-member.
2001CamaroGuy, buy one and tell us if it worked .
Old 03-07-2004, 03:21 PM
I almost did but then was smart enough to go out and LOOK at the car. I noticed that the f-body oil pan is notched to fit AROUND the K-member......looks close even on the BMR.
Old 03-08-2004, 01:30 AM
Dope's Avatar
Good luck fitting it. That's the reason why we didn't get the vette oil pan, cuz it don't fit
Dope
Old 03-08-2004, 02:54 AM
66ImpalaLT1's Avatar
My car is on jackstands right now, do you want me to measure it? Its pretty wide.
Old 03-08-2004, 12:47 PM
sure.....give me some measurements:
- from the block rail (where the pan mounts on the block) down to the bottom of the front
- how far from the front to the point where the rear part (sump) starts (sloped down)
- how wide the "wings" are
a picture would be nice too
Quick Reply: Corvette oil pan on F-body
