Valve Spring Micrometer
Old Sep 17, 2011 | 05:36 PM
LeftySS's Avatar
Default Valve Spring Micrometer
Just wondering if the valve spring micrometers fit over the one piece seat/seal or do you have to remove them to measure spring height?
Old Sep 17, 2011 | 05:40 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...icrometer.html
https://ls1tech.com/forums/lt1-lt4-m...e-springs.html
http://www.cpgnation.com/forum/comp-...tech-2047.html
Old Sep 17, 2011 | 05:59 PM
JS01's Avatar
Should fit over it. If it doesn't you could always remove the seat, measure your spring height and then subtract the thickness of the seat from your measurement.
Old Sep 17, 2011 | 06:01 PM
Whistler's Avatar
Sawzall and Welder Mod
Keep in mind that the smaller beehive retainers used in many LS engines dont sit in the proper seat on some VS mics. Measure the mic with a caliper to see where the right spot for the retainer to sit is.
Old Sep 18, 2011 | 10:34 AM
OldCobraGuy's Avatar
Mine from comp fit just fine.
Old Sep 19, 2011 | 04:09 AM
vettenuts's Avatar
Good point, I made a shim that filled the pocket in the top of the micrometer to measure directly.
