Compression Ratio Help
Old Sep 21, 2011 | 12:25 PM
WSsic66's Avatar
Default Compression Ratio Help
Texas speed Lq9 370 Short Block
forged -2cc diamond pistons 4.03" bore piston
forged I beam Rods 6.125"
MLS head gasket
patriot Stage 3 72cc chamber heads
7.4 harden pushrods
Trex cam
Fast 102 NW setup
Can anyone help me out figuring compression ratio?
What thickness of gasket should I run (200-250shot direct port in future)
Old Sep 21, 2011 | 01:06 PM
WSsic66's Avatar
does 11:1 seem right?
Old Sep 21, 2011 | 01:55 PM
FlamingTA's Avatar
I could be wrong but if you are using a stock .051 gasket, 0 deck height, I get 9.9
Old Sep 21, 2011 | 01:58 PM
FlamingTA's Avatar
Or did you mean 62cc chambers?
Old Sep 21, 2011 | 05:45 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
With a 72cc head, a-2cc flat top piston, and a stock MLS gasket you would be at 9.88:1 according to my compression calculator.
Old Sep 22, 2011 | 03:46 AM
WSsic66's Avatar
I will be running the 72cc heads I accidentally purchased the wrong ones.
So now I guess im stuck what to do.
Sell the heads. or use them
I really want most my power from nitrous.
can I now safely add a 300 shot?
Old Sep 22, 2011 | 10:53 AM
You could always mill your heads to get some extra compression if you want. Since the piston has a valve relief in it you have the room. Do you know if the motor was setup for a 300 shot as far as ring gap and bearing tolerances? 300 is a lot of nitrous and if the motor was not setup to be hit that hard it might not take it very well. I would check with your engine builder on that one.
Old Sep 22, 2011 | 10:58 AM
WSsic66's Avatar
I will be purchasing the engine from you guys I am torn between 370 or 408 LQ9. I just got a killer deal on my heads I really dont want to sell them if I dont have to.
How much would have to be milled off if I where to go with a 408? I believe an 11.1-11.5:1 is the compression ratio I would want for the street.
Old Sep 23, 2011 | 01:12 PM
I would definitely recommend spending the extra money for the 408. It will make a noticeable amount more power. With the 408, your heads milled to a 70cc chamber, and a cometic .040" gasket you will be at 11.3:1. Make sure you build the 408 with the Wiseco -3cc flat top piston and that will get you where you want to be compression wise.
Old Sep 24, 2011 | 11:00 AM
WSsic66's Avatar
Thanks you've been a big help a 408 is in my future by april 2012
