TRex Vs. G5X-3
I'm stuck between these 2 cams as they both sound great. It sounds like the TRex will be the cheaper way to go. $1300 sounds like alot for the X3 package, but, I hav yet to add up all the needed parts from TR's website, so, it may be around the same price. I'm also assuming flycutting is a must? The car is NOT a daily driver, just a weekend whoop-sum-*** machine.
the more lopey and nasty, the better. Gear selection? I was thinking 4.56's
, whenever I could get a better rearend...Thanks for any input. I also might spray a lil on down the road.
Call TR and ask for Paul he will set you up esp if you are not sure on all you want.
For tuning you will need to read the posts in the PCM section. If you are getting LS1Edit to tune read their manual and join their mailing list. If you go for HPTuners product join their board.
Shifting will depend on your dyno results.
ARP rod bolts are your best protection. Read the post in this section about reving to 7K. You can do it but no tellin' how long it will last.
BTW, last time I talked to Paul at Thunder he said they did not rent the tool. Brent at TEA said they did but it was out right now.
Go to UPS.com and you can get shipping estimates or call TEA and ask them.
You need to fly cut because you have milled the head and your valves are closer to the piston. Plus you have large valves which will be closer to the piston.
Hope this helps.
